Question about Kodak Ektagraphic Model B-2
Kodak ektagraphic slide projector wont turn on
I just got this projector from my highschool. According to the librarians, its been sitting around without use for about 10 years. It was working completely fine for about 25 minutes. Then the advance and reverse buttons stopped working, I just moved the carosel by hand. Then, all of the sudden the projector shut off and will not turn back on.
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, We may have to dig in the archives for this one but I will give it my best shot !!!! The unit has a main fuse, one of those glass types. It sounds like it blew the fuse. You may need to have this unit serviced by a repair shop. If you replace the fuse make sure it is of the same amp rating as the old one !! This is very important as to not start a fire.
Best Regards, Russell
Posted on Jan 24, 2013
leethedeuce
  • 4472 Answers
SOURCE: lens error messages
Looks like the only thing to do is send it in for service, which if it's out of warranty is not very cheap. Or you can sell it on ebay or craiglist and use the money to buy a comparable one.
Good luck,
Lee
Posted on Jun 15, 2008
SOURCE: Kodak M753 wont charge
I hope this will work for you.
Clean all the gold termanels with a cotton swab and a little alcohol.
Make sure all surfaces are dry. Before you try to use it.
Posted on Apr 15, 2009
SOURCE: my kodak m340 was fine suddenly it wont turn on
i don't no use camera
Posted on Feb 02, 2010
  • 11967 Answers
SOURCE: camera wont turn on
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 20, 2010
slimboga
  • 82 Answers
SOURCE: Kodak Z 1285 shut down while transferring pics - Won't start up.
you can look on the kodak home page if exist a new update to resolve this problem. but i am very sorry for you why this is a not good signal. its probably that the camera have a processor problem and dont read no more the cards. prove to first to change the card type. and look that the card have not a hold bloc system. this is the first prove change the card look if kodak have updates for this problem of the hompage of your specific model. and good luck
Posted on Jun 01, 2010
Fix focusing on ektagraphic remote control
Ektagraphic III A did not have remote focus. Someone has probably substituted a remote from a higher functioning model on this projector. The forward / reverse functions on the supplied remote will continue to function correctly, but the focus buttons will not.
Good Luck !! Jim
May 20, 2014 | Kodak EKTAGRAPHIC III A Slide Projector
Slide projector is loading slides too fast
On an Ektagraphic III-A there is an internal adjustment you can make of the wire that captures the slide change mechanism after one revolution (or ONE slide change). Over time and usage that wire either breaks off, burns off or gets out of adjustment. Look at the attached diagram for more detail:
Feb 15, 2014 | Kodak EKTAGRAPHIC III A Slide Projector
Kodak Ektagraphic AF -2 carousal not rotating
Given the age of the projector, I suspect that the solenoid link is broken. The link joins the solenoid plunger to the cycle lever. The good news is you can still buy parts for your projector. www.micro-tools.com purchased the entire projector parts inventory from Kodak a few years ago. They can also help you with instructions to install the parts, or if you prefer, hook you up with a trained service technician to perform the repair for you. Good Luck! Jim
Nov 28, 2012 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
Shutter stuck on Ektagrahpic III projector
First of all, the shutter will only open IF there is a slide in the gate. Assuming there is a slide in the gate, there are 2 things that could be preventing the shutter from opening:
1. Most likely - the shutter is spring-loaded. If the spring unhooks or is missing, the shutter will not open.
2. There is an adjustment that needs to be made after the spring is replaced or re-hooked (or just is out of adjustment. Refer to the Kodak Ektagraphic Service Manual @ the Kodak web site: http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf
Good Luck! Jim
Aug 18, 2012 | Kodak Ektagraphic III ATS Slide Projector
How do you remove the working parts from the outer case of Kodak Ektagraphic E2
This is NOT an easy question to answer. You need service manual & parts list for an E-2 to be sure you remove the components in the correct order. Check with www.micro-tools.com to see if they have service documentation on their website. They have purchased all remaining projector parts from Kodak, so if you need parts, they are a great resource. Sorry I can't help more! Best of Luck !
Jun 26, 2011 | Kodak ATS Ektagraphic Slide Projector
Kodak Ektagraphic model B-2 slide projector.- It does not start. I checked the power cable and motor OK but I don't know how to reach and check the thermal fuses. I also don't know how to reach the...
If the motor is "OK" (turning), then it's not a fuse, it's the belt that the motor drives to power the slide change mechanism. There are 2 belts: 1 that drives the fan & one that drives the slide change mechanism.
Nov 02, 2010 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
Need manual for the slide projector
You can download the User Guide from the Kodak website:
(http://www.kodak.com/global/en/service/products/ekn010374.jhtml?pq-path=6499/4529).
Jun 16, 2010 | Kodak Ektagraphic III E Plus Slide...
I live in nyc where can i get replacement bulbs for the ektagraphic
The KODAK Ektagraphic ATS uses a 82volt, 300 watt ANSI code "EXR" lamp. You can order "EXR" lamps from Bulbman (www.bulbman.com)
Apr 19, 2009 | Kodak Ektagraphic III ATS Slide Projector
Does bulb need replacement?
I had same problem.
You have to load the slides so there is something to be projected.
Dec 15, 2008 | Kodak Ektagraphic III ATS Slide Projector
Kodak Ektagraphic III AMT: turn on and it advances on its own without stopping
This is a "wear problem" called continuous cycle. Pretty common, actually. It requires an adjustment of the cycle contact wire. Unplug the projector, turn the projector upside down and remove the lamp module from the back. Remove the six T-15 TORX screws that hold the bottom cover in place. Gently pull (the power cord is secured to the inside of the bottom cover) the bottom cover off & lay it next to the projector. Near the center of the projector you will see the cycle wire and pad (refer to the attached pic). You will need to carefully(!) bend the "J"-shaped wire so that when the projector is "idling", the wire lays at the center of the pad. Bend a very little, plug it in and cycle it a couple of times. If it still continuous cycles, unplug & bend a little more. It usually takes 3 or 4 adjustments before you get it in the correct position. Good Luck !!
Oct 06, 2008 | Kodak Ektagraphic III E Plus Slide...
Kodak Ektagraphic Model B-2 Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
