Question about Sony PlayStation 2 (PS2) Console
Adjusting the lens height using the gear
I have a scph-50004 ps2 but the problem is i have 2 gears to adjust (small one) now do i have to make them exactly of same angle or should the lens be a little slanted? i Have adjusted both of them to have the same angle but is that bad? I am not getting the best results on all games. Thank you in advance
    Problem Solver:
  • 8 Answers
First do what i did. get a dvd movie,a ps one game,a cd based ps2 game (timesplitters,rune,dynasty warriors 2,half life)a dvd based ps2 game, and a scratched ps2 game. first adjust the azimuth(the torx screw to the left of the laser} make sure you use a cue tip and 91% alcohol on the lens and under the lens(you have to remove the black cover off the laser). I just got a broken ps2 for 5 bucks and that made it work perfectly.make the azimuth adjustments in 1/8 turns. try all games and especially the dvd movie carefully pull the white plastic wheel out of the top cover for the dvd drive. and pop that on the disk while its in the drive. turn it on and note what happens. if a disk is in the drive before it's powered on you should never see the browser it should just boot.If not you have problems. once all disks are booting good get a problem disk (I used a scratched tony hawk 3) and if the audio skips or freezes adjust the white cog wheel counterclockwise in 5 click intervals until it works perfect. if you are lucky it will work like new if not you might have a laser voltage problem and to fix that you need a variable scope ososcillator ( i know i missplelled it) under the laser is 2 pots to adjust the voltage for the cd laser and the dvd laser. the left is the cd one if its facing you. you can find the proper waveform pattern online in various places.i would just buy a Used ps2 because there preety chaep and definetly cheaper than the stuff needed to adjust the voltage correctly.IF YOU TRY TO ADJUST THE LASER YOU MAY BURN IT OUT.I did on my first one but since my friend was using it as a window stop and i got it for free i donn't care.So hopefully it works out for you guys. if i were you just buy a SEGA DREAMCAST it has none of these problems and is cheap as hell..............................................
Posted on Jul 06, 2007
Chain intermittently slips in all gears. Is there an adjustment
Mark:
First of all, make sure that you are not over or under shifting. The chain has to be positioned exactly over the gear that you are trying to use. If you hear derailleur or chain noise The derailleur is not "in gear" and you have to adjust your shifter to eliminate noise. The derailleur must be adjusted so that the chain is parallel to the gear cluster in each gear. If the chain is twisted at all, it will skip gears. Check your rear derailleur to ensure it is pointing the chain directly at the front gear cluster. Check the front derailleur to see that it is pointing the chain directly at the rear derailleur. While you are at it... clean the derailleurs with alcohol and lube them with a light weight oil. Check the derailleur stops (small screws next to the cable clamp on the derailleur). Have the bikes rear tire off of the ground and pedal the bike with one hand while shifting with the other hand and you can see what the derailleur is doing. adjust the stops so that you can not shift the chain off of the gear cluster in high or low gear. You may have to adjust the cable length at the derailleur cable clamp, and at the adjusters on the shifter to get the exact adjustment that you want. It will take some time to properly adjust your derailleurs, but it is worth it when you can ride without your derailleurs acting up.
Jun 15, 2015 | Cycling
Not cutting short enough
There should be two sets of holes for the deck mounts. Check and see if it is in the upper or lower hole. Place in lower hole if applicable. Also ther is an adjustment nut on both side of the mower deck that has a jam nut and a gear nut. The gear nut adjusts the height of the mower deck on each sid here is link that might helpe. Loosen jam nut and turn to go up or down. Then tighten jam nut. This should be done on a level surface. here is a link that will help you as well.: http://homeguides.sfgate.com/adjust-deck-height-husqvarna-100712.html
Mar 26, 2014 | Husqvarna Garden
I misplaced my ktm adjustable rear set manual, how...
the gear shifter and the brake pedal should be set even with the footpegs.. the same height so when you rest your foot on the peg it should be right on top of each.. hope that I could help
May 16, 2010 | Motorcycles
Problem with chain and gears
Wash, degrease and scrub the chain and derailleurs with a good degreaser (like Simple Green). Dry the chain and relubricate it with an appropriate bike chain lubricant (not oil or WD-40). Shift the derailleurs to the smallest chain ring and cog on the cassette (low front gear, high rear gear) and then loosen the cable at the derailleurs, pull the cables taut and reattach them. If the derailleurs still need adjustment, here is a procedure for it:
Flip the bike over (so you can pedal the bike manually while you shift) and shift the front to the middle chain ring. Shift the rear to the highest gear (small cog). Release the cable from the pinch bolt on the derailleur. Adjust the screw marked "H" on the derailleur until the jockey wheel on the derailleur is aligned perfectly over the small cassette cog. Set the cable adjuster on the derailleur to the middle of its range (find this by screwing it all the way in and then count how many revolutions it makes until it screws out completely. Screw it back in one half of the total revolutions). Reattach the cable and shift to the lowest gear (the biggest cog). Over-shift and hold on the shifter, then adjust the "L" screw on the derailleur until the jockey wheel sits just past the last cog. You have to hold the shifter to do this. Now shift into the middle gear (or one of the two middle gears if the bike has an even number of gears) and adjust the derailleur using the barrel adjuster you previously set to the middle of its range. Adjust it so that the derailleur is sitting perfectly over the appropriate gear. Shift up and down the cassette while pedaling and in every gear, reverse pedal (freewheel) to make sure the chain does not hop. Adjust as necessary until all gears are smooth.
Now the front:
Set the rear derailleur to the lowest gear (big cog) and the front to the lowest gear (small chain ring). Disconnect the derailleur cable. Screw in the adjuster for the cable tension all the way (this adjuster is on the shifter of a mountain bike or the down tube of a road bike). Pedal to make sure the chain is not rubbing on the derailleur cage. If it is, adjust the "L" setting on the derailleur until the chain moves by without touching the cage. Now pull taut and reattch the cable and shift the front to the big ring while pedaling. If it does not shift up well or completely, hold the shifter past its normal shift and adjust the "H" screw so that the derailleur allows the shift. Shift into the highest cassette gear and keep pedaling. The chain should not be touching the front derailleur's cage when you pedal. Adjust with the barrel adjuster until the chain moves freely without touching the derailleur cage.
That should be it, unless there is another mechanical problem causing the missed shifts, like a bent derailleur hanger or damaged teeth on the cassette cogs or a bad derailleur. If it is still problematic, come back for further information.
i hope this helps
-matthew
Oct 26, 2009 | Cycling
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
Sony PS2 SCPH-30003 No data error. PLS Help
You should never open any DRIVES like DVD or CD drives even for your PS2, There has to be a problem with you lens in your PS2.
Mar 07, 2008 | Sony PlayStation 2 (PS2) Console
Camera lens
spounds like theres a problem in the lens gearing system. if theres a jammed gear and you try to force it you WILL cause 3 times the damage to the mechanism.I fyou know how and only if you know how to dissassemble the front case as well as the lens cover then see if when yoiu loosen the drive motor if you can move the unit or lens assy. if you can then the gear system inside the motor its self is bad and the whole motor assy has to be replaced. if I were you I would contact number800-488-7669 and find out what they charge to repair the camera. Good Luck
Apr 15, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony PlayStation 2 (PS2) Console Logo
1,162 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
