Question about GE GFSS6KKYSS
Ice under Deli drawer - GE GFSS6KKYSS
2 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: GE Profile side by side...water collects under the
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Oct 27, 2009
What is causing ice buildup under deli drawer?
condensation due to either clogged plugged evaporator drain hole line. or a bad door seal or seals allowing moister and air to condensate? then freeze as u may also want to check ur damper air flow to see if its to far open as per the freezing? even ur cold control thermostat may be set to high
Mar 21, 2015 | Refrigerators
Items in deli drawer keep freezing
is the freezer freezing too? to much ice build up? if not check ur damper vent, make sure its not stuck closed or open to far, check the thermistors, the tempeture control thermostat, defrost timer and defrost terminator
Feb 19, 2015 | Kenmore Refrigerators
My Kitchenaid refrigerator deli drawer freezes everything, how can I fix this?
Check the air flow vents for ice buildup, this happened with my whirlpool fridge. Hope it helps.
Feb 03, 2015 | KitchenAid Refrigerators
Frigidaire French door model 28 cubic ft - deli drawer freezes cold cuts and cheeses. Model FGHN2866PF1
Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
Oct 10, 2014 | Frigidaire Refrigerators
Water is collecting under the deli draw of my french door samsung refrdgerator
Is this the Samsung 4-door fridge/freezer with a round water-filter between the two drawers in the Refrigerator? a) Is your water-filter correctly installed in it's place? b) check where the water-drops are coming from: it could be the ice-maker - need to call Samsung service.
Sep 28, 2014 | Samsung Refrigerators
Ice under the deli drawer
it could be that u have a leak.. sometimes this happens when to much water is delivered to the ice tray and it overflows a little leaking into fridge. if that is happening then u most likely have a problem with the water inlet valve at the back of fridge, u can buy the part on line at appliancepros.com. good luck
Apr 13, 2014 | GE Refrigerators
Water under samsung refrigerator deli drawer
You posted this question in FixYa's cellular phone area. You'll fare much better if you repost this question in the refrigerator area. Include the model number of your Samsung refrigerator if you know it.
Dec 20, 2012 | Cell Phones
GE Profile side by side...water collects under the Deli drawer...it's so bad we keep the Deli drawer out and a towel in the space to soak up the water. Any thoughts?
Oct 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
GE GFSS6KKYSS Logo
63 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
