Freddrick ptac a/c unit comressor never comes on relay on compressor seems good,m what now?
  • 163 Answers
Hi!! change you start capacitor also check for amps going into the compressor.if power is going then ohm out compressor.Short compressor..
Posted on Jan 20, 2009
Amana PTAC PTH093E Fan runs at single speed only regardless of setting-auto/low/high Hot or cool air is coming out so compressor/heat coil is working. Reset unit and replaced fan motor-no change.
I've replaced many Amanda control boards. They have micro relays attached to the board. These relays are about a half inch by 1 inch in size, and control line voltage to the compressor and blower motor, and give up quite often. Its probably the board if its a digital controlled board. If it has manual, turn to select, type knob, it will be in that fan section knob. Hope this helps!
Mar 13, 2017 | Amana Heating & Cooling
I have a Friedrich Ptac unit Model PDH15K5SE-A. The unit turns on ok but does not heat. Need advice what to do. Thanks
Does the unit cool ok? If yes, you likely have a problem with reversing valve. If no, likely a refrigerant problem.
Mar 01, 2017 | Friedrich Heating & Cooling
Ge ptac unit model az32h15d3bm2
if the compressor is NOT running you have problem with this devices:
Compressor Overload and/or relay Thermostat (Open thermostat) Burnt wiring Bad selector switch Capacitor test any devices.
May 09, 2012 | Heating & Cooling
If I strap terminal 3 to 5 on the compressor relay the compressor comes on. What controls the compressor relay?
THE LOW PRESSURE SWITCH
SYSTEM IS PROBABLY LOW IN FREON
TO CONFIRM LOCATE LOW PRESSURE SWITCH AND JUMP
THE TWO PINS IF COMMPRESOR ENGAGES THR SYSTEM IS LOW
DONT LEAVE IT JUMP YOU WILL BLOW UP COMPRESSOR
NEEDS FREON TO CARRY COMRESSOR OIL TRUE OUT SYSTEM
May 07, 2011 | Chevrolet Lumina Cars & Trucks
Comressor takes 34ams when switched on what is the
The compressor is in a locked rotor condition..which means that it is trying to spin but cannot, probably because of a mechanical failure within the compressor...
You will need to replace the compressor, but for most window units it is cheaper to replace the whole unit...
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Apr 15, 2010 | LG LB1200ER Air Conditioner
AMANA PTH153B35AE PTAC Temp drop??
PTAC temp drop should be 20 to 25 degrees across the coil. They never put a service tap on these units. I sell Amana PTACs. You may be alittle low on gas. Check your air TD and that will tell you. The compressor may be overheating due to lack of cool gas to cool the comp. May need a service tech but get a free estimate first. Rus
Jul 04, 2009 | GE Zoneline AZ55H07D Air Conditioner
Comressor won't kick in...
Check contactor on outside unit for burned contacts. Try to manually press the contactor with INSULATED screwdriver to test. Should be some **** on cotact buttons. Hope this helps. Let me know. Good luck
Apr 27, 2009 | Heating & Cooling
Will not switch to cool mode. heat and fan work fine
hi,
regarding on switch mode theres a common line between heating and cooling although fan is always connect on them.,also with the thermostat,the sequence on this when you switch to cooling and your connection is on heater,the contactor will shift to compressor source,so if there is no cooling, the contactor supplying the compressor is not functioning when you switch on cool mode.try to tighten screw on compressor relay maybe only loose.on control panel,or check continuity of compressor if the compressor still good,check also the freon charge using clamp ammeter,this should be done by ac technician.have a nice day
rate me up,thank's
Apr 26, 2009 | Heating & Cooling
TRANE PTAC
You need to replace your control board, but if you are can repair it by your self you can change the relay that supply the fan and condenser.
Nov 15, 2007 | Heating & Cooling
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
