Question about Dell 1710n Laser Printer
Dell 1700n printer
I have always owned ink jet printers, but company sent 1700n printer t work with. I replaced the toner cartridge and started getting lines in printed material. I figured things were dirty so I wiped off new cartridge and face of drum. Well now I have the print coming out all messed up with gray shawdowing everywhere. Did I mess up when I wiped off drum with paper towel and is a new drum the only way to fix is?
  • 432 Answers
Print out about ten or more sheets and see if it clears up.
Posted on Jun 27, 2007
SOURCE:
New Dell 1710 laser printer is generating faded characters
This usually happens when the toner is running low.
Try removing the toner cartridge and shake it in a horizontal position and insert it back in the printer. This may give you a few more printed pages before you have to get a new toner cartridge.
Feb 09, 2011 | Dell 1700n Laser Printer
What to do when toner is low
Remove the toner cartridge.
Gently "roll" it from side-to-side, to evenly distribute the toner. Do not "shake" it.
Eventually, you'll either need to buy a new toner-cartridge (either from Dell or via eBay) or find a store that refills ink-jet and ink-toner cartridges.
Apr 16, 2010 | Dell 3000cn Laser Printer
My Dell 1700n Drum and Toner Cartridge were both replaced when the drum replace light blinked and the print was getting lighter. Despite resetting the Drum counter the printer still only prints faintly...
Have you checked the fuser?
A laser printer fuser assembly is the heating roller unit that melts and fuses the toner onto the paper. The fuser assembly is made up of a heating roller and a pressure roller.
The heating roller applies the heat to the toner on the printed page and the pressure roller presses and fuses the toner into the printed page. If it's bad and not heating properly, the print will be faint, which is what you describe. You may be able to remove and clean the fuser, but if the printer gets lots of use, it may just be worn out.
See this link for an idea of what it looks like and a price.
http://www.fastprinters.com/ProductDetails.asp?product_id=DELL-H4919
I do not work or represent this company, so shop around.
Mar 22, 2010 | Dell 1700n Laser Printer
Printer ink
You can use refilled toner cartridges or off-brand compatible toner. The plus side to this is they are far cheaper and they do work. The down side is that they may increase wear on your printer and if they are the cause of a printer malfunction your Dell warranty is not required to fix the problem. It's a calculated risk--one which I personally take (three or four replacements of toner save enough to buy a new printer).
May 05, 2009 | Dell 5110cn Laser Printer
Ink cartrige dell 1110
Maryfrancesh
Exerpt taken from Dell Laser 1100 User Manual (p30)
1 Open the front cover.
2 Pull the used toner cartridge out and lift it up and away from the printer.
3 Unpack a new toner cartridge. Hold the cartridge carefully and gently shake it from sideto-
side 5 or 6 times to distribute the toner.
4 Pull the tape to remove the protective paper.
5 Locate the cartridge slot inside the printer, one on each side.
6 Unfold the toner cartridge handle and grasp it. Insert the cartridge into the printer until
it snaps into place.
7 Close the front cover. Make sure that the cover is securely closed. If it is not firmly closed,
printing errors may occur.
PDF Manual can be found here -->
http://support.euro.dell.com/support/edocs/systems/1100/en/OM/OM_1100_en.pdf
The guide also contains pictures of what to do.
Andy
Jan 29, 2009 | Dell 1110 Laser Printer
Dell 5100cn code 009-363
Nicholas -
There is no real solution to this problem that I've been able to find. And I myself have not been able to find anyone that has the service manual for this color printer.
Here is what happened with my printer. I normally use this one company for compatible toner cartridges for our office printers. I've never had any issues with their HP, Brother, Canon Phaser or Dell laser products - EVER. When I went to re-order my Dell 5100cn toners again from them - ordered 2 black and 1 each cyan, magenta and color - none of the toners worked right. When they were installed, the machine produced that 009-363 restart printer message.
Now this company has ALWAYS taken care of me. We thought maybe the chips in the toners were outdated or something compared the the recent firmware update my printer had recently had. So they shipped out a complete new order for me. But the second set of toners did the same thing. So they sent one of their Dell Certified technicians to the office - we are on a cleaning plan with them so he just looked at the Dell printer while he was there doing the other work. He could not find anything physically wrong with the first or second set of toners, but yet they would not work in my printer. He even tried going through the menu options to select "allow non-Dell toners" too - thinking that maybe the printer just wasn't liking the Dell compatibles. I never had to do this before with their Dell compatibles, but it was worth a try. But even when selecting that, the printer still produced the 009-363 restart printer message. He took the toners back with him, and left me with a set of Genuine Dell toners - just to get me through what was happening so I wasn't down a printer.
The company called me and said when the technician returned with the compatible Dell toners they'd shipped me, they installed them in their test Dell 5100cn printer and they worked fine! So it was appearing that the problem might have been my machine or something.
I searched online everywhere, and the supply company I used also spoke with Dell tech support on my behalf - but got no where with Dell as usual - their Tech Support is totally useless!
About a month goes by, and my supply company says that they received a new shipment of Dell chips that have a newer firmware than even what my printer has, and that they'd like to send their technician out again to test them out in our machine. The tech came by, installed all of the toners - and they worked!
So it definitely was something to do with the firmware that was on my printer versus the firmware that was on the chips in their toners. My printer for some reason did not like that "lot" of toners they had made using those chips. And when they produced their next lot with the new firmware chips, the printer accepted everything ok.
Since then I've used their Dell compatibles with no issues. I think it was just a fluky thing as it hasn't happened since. Overall I think you just need to find a company like mine that continuously produces new toner cartridges using new Dell chips in their toners. Once in a while you might get a fluky one like we did, but my company definitely took care of us. Just try to find a company that has a good cartridge - you don't have to keep buying the expensive Dell brand - especially when they don't even know what the problem is caused by either.
Jul 01, 2008 | Dell 5100cn Laser Printer
Refill Toner Cartridge for Laser Printer
Nobody has a clue how to refill a laser cartridge with ink. :)))
OK< just kidding, here it is:
First of all, laser-cartridges have toner (a fine black powder) and not ink.
Second: There are 2 methods to refill a laser cartridge: dismounting it to get to the toner chamber (involves a lot of tehnical skill) or the melt-and-pour method (see here http://www.urefilltoner.co.uk/), but you need the melting device.
But because from your question i see you dont know a thing about refilling, better go to a refill center.
Feb 14, 2008 | HP LaserJet 1012 Printer
Dell 1700N Laser has burning plastic smell
Depending on the age, there was a safety recall on this printer a couple of years ago for an overheating and possibility of fire. If I remember correctly, it was printers made in 2004 or 2005. Should be something on the web (consumer product safety).
Mar 29, 2007 | Dell 1700 Laser Printer
Dell 1710n Laser Printer Logo
159 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
