Question about Kwikset Smart Code
My kwikset smart code keeps auto locking every 30 seconds
SOURCE: I just installed a Kwikset lock but when I put the
i hope this helps someone. i just spent three hours trying to fix this problem. this occurance happens when the internal assembly is screwed down too tight to the door - somehow it doesnt give it enough give to turn the lock 100%. just loosen up the screws from the assembly to the door, and everything should now function correctly.
Posted on Sep 12, 2010
kel1guy2002
  • 3740 Answers
SOURCE: how do i change the
Hi and welcome to FixYa, I am Kelly.
Here is the manual. (link below) See step 9 on page 6.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
My interpetation:
Slide the interior cover off. Locate the program button. Press program button, enter code. press progran button. You can also enter a 2nd code by pressing the program button 2 times, enter the code, press program button 2 times. Re-align the interior cover after programing code.
Thanks for choosing FixYa,
Kelly
Posted on Apr 20, 2011
  • 963 Answers
SOURCE: H do I reset all
This link will take you to the PDF image of the installation and programming instructions:
(PDF files require that you have Adobe Reader or similar installed on your computer
http://get.adobe.com/reader/ )
It's a good time to replace the batteries while you're reprogramming. Please review each step carefully, because it's easy to goof up this programming process, if you don't follow the procedure properly.
Posted on Jun 27, 2011
aquaman987
  • 927 Answers
SOURCE: I moved into a foreclosure
a. Press the program button on the interior unit once.
b. Enter in 4 to 8 digit code onto the keypad.
c. Press the "LOCK" button to save code.
d. Extend the bolt by pressing the "LOCK" button and re-enter the code to test. The bolt should retract to the unlocked position. If it does not unlock, repeat steps (a) through (c).
This is from another Fixya Expert.
To get to the program button, you have to slide the interior cover off.
There are AA batteries that should be replaced.
Gary
Posted on Jul 13, 2011
  • 963 Answers
SOURCE: waustin@lnshow do i reset a
Here's the installation instruction link for your lock:
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
Posted on Nov 05, 2011
I think the lock control pad circuit board is defective, whether that is repairable or you just replace the lock I have n idea, these are really not in wide use.
Mar 01, 2017 | Kwikset Locks & Locksmithing
Keeps beeping even with new batteries
The auto lock setting must be on and it will continue to beep as long as the door is not locked.
Apr 02, 2013 | Kwikset 909 909-15 Satin Nickel Smart...
Need to reverse bolt
Called "handing" the lock (left-hand or right hand door hinges):
Remove the battery pack. Keep the door open.Hold down the "Lock" button on the exterior keypad and at the same time, insert the battery pack into the interior assembly. Keep holding down the lock button until you hear two beeps, which will take approximately 30 seconds. During that time, the Smartcode mechanism will automatically drive in and out several times to determine proper handing.Done!
There is an excellent installation & programming video where you can watch how to do this, and it also explains the features of the internal slide switches.
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Apr 04, 2012 | Kwikset 909 909-15 Satin Nickel Smart...
How do i get the smartlock to relock on its own without having to push the lock button
For reference, here is a link to the installation guide:
Under Step 11, you will see that if you change the switch position of the second switch (of 4) internal to the lock to the ON position, it will enable auto-lock of the door 30 seconds after unlock.
Hope this helps!
Jul 19, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Our kwikset 909 will not lock on its own- we have to hold the lock button. How can we get it to lock automacally like it is supposed to do.
Hope this helps!
Kwikset Smartcode electronic lever, # 911LL Auto Lock feature keeps relocking every 30 seconds! How do we fix?
Here's a link to the Quick Installation Guide for your lock:
http://s7d5.scene7.com/is/content/BDHHI/smartcode-lever
When you scroll to the bottom of this page, it illustrates the four-switch slide switch internal to the lock. Switch 2 controls the 30-second auto-lock feature, so slide the second switch to the other position.
Jul 16, 2011 | Locks & Locksmithing
I just got one of these gave to me from nieghbor lock not real old and in good shape its never seen weather. When you install the battery's it trys to lock then keeps tring to lock for like 30 seconds or...
Here is the link to the installation instructions:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I think that you may have the door jumper set in the wrong position for the way your door opens (door handing; see page 6 of the instructions).
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
Good luck--and please provide feedback if this helps!
Dec 03, 2010 | Kwikset 907 907-15 Satin Nickel Smart...
I just install my kwikset finished smart code signiture series touch. But its unlocking when I press the lock button instead of locking. Is there anyway to lock it in the other direction?
You have to take the batteries out then hold down the lock button on the outside of the door and slide the batteries back in wait for a couple seconds..... Let go, push the button on the inside to program your lock code .....enter your lock code and then hit lock button. It should work, coustomer service number is 1-800-327-5652
May 22, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
How do i reset the codes
kwiset smart code How do i reset the codes
Oct 07, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
I just installed a Smartcode Deadbolt and I follow the directions but I cant program a code and it trys to lock itself every 30 seconds. what do i do
On the back of the unit slide the cover off and push the 2nd switch (on the contorl panel of four switches) down.
To program the code, push the black button once and enter a 4 to 8 digit code, then press the middle lock button. To set a secondary code, press the black button twice, enter 4 to 8 digit code and press the lock button.
This should all be self explanitory in the instruction manual.
I have one of these on my front door and its fantastic. I carry a key but have not used it in months. Bravo Kwikset, Bravo!
Aug 14, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
Kwikset Smart Code Logo
333 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
