Question about Vizio Televison & Video
Vizio E291-A1 audio shuts off spontaneously
Audio shuts off spontaneously, sometimes as frequently as 1 or 2 times in an hour. TV does not respond to Dish Joey remote or the TV's remote, and must be restarted to get audio back. No other devices besides Joey connected.
  • 87 Answers
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Posted on Oct 23, 2007
SOURCE: vizio tv has audio but no picture
My vizio has the same problem, no picture with only sounds. I tried calling vizio for help but their customer service and or tech support REALLY **** big time! They tossed me around to here and there with no solutions. My only suggestion to you is that, tell everyone related to you or your friends to not ever buy vizio again. Too many people is having problems with these sucky tvs. I'm still not sure what I am going to do with mine. Maybe I'll just let it fly down from a three story building!
Posted on Aug 05, 2008
  • 3 Answers
SOURCE: vizio tv
Mybe the sleep timer is on? check and make sure that is turned off
Posted on Sep 15, 2008
  • 10 Answers
SOURCE: Vizio won't turn off
This could be a mainboard problem. Sometimes one of the fuses may be bad and may freeze up causing the TV to not be able to power off.
Posted on May 23, 2009
SOURCE: No Audio in my Vizio HD TV
I solved the problem by going into settings. Then audio. I had one of the audio settings turned off
Posted on Oct 06, 2009
Vizio E291-A1 serial# LTTMNVAN3806392. TV will not work until to unplug/replug multiple times.All that comes on continued below
I would never guess, before you know it you will have more money in the repair then what a new set costs.
Jun 20, 2017 | Vizio Televison & Video
Vizio tv model e390-a1 no audio. Tried pc speakers logitech s120 from audio out only get hum.can I fix internal prblem myself?
check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Dec 22, 2016 | Vizio E390-A1 39" 1080p 60Hz LED 2.95"...
How difficult is it to replace a blown speaker on a E500 Vizio TV?
Easy if you can get inside the case.
Audio Speakers 2 Subwoofer No Effects SRS StudioSound, SRS TruSurround HD, SRS TruVolume Total output power 20 watts
Read more: http://www.digitaltrends.com/tv-reviews/vizio-e500i-a1-review/#ixzz3vkDj3Zwp
Follow us: @digitaltrends on Twitter ' digitaltrendsftw on Facebook
Or you could buy a surround sound speaker bar which disables the internal speakers.
Dec 29, 2015 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
When I attempt to turn on the TV, the power button will light up, but there is no picture.
Main system control memory IC fault. [System reset section circuit]. Contact any service technician to get this set repaired.
Aug 14, 2015 | Vizio E291-A1 29" 720p LED-LCD TV - 16:9 -...
How do I make my remote work? It was working then it stopped. I thought it was the batteries, so I bought new ones but it still wont do anything.
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Vizio XRT010 Remote for E320-A0 E241-A1...
Vizio E291-a1 no power
There are 2 screws on the bottom of the unit, and 1 on the back. The back snaps tightly onto the front. Unplug the unit (naturally) and very gently, starting at a corner pry the back off the front using 2 small screw drivers. One to lift the back off and the other to pry the edge of the from from the back.
Mar 11, 2014 | VIZIO, INC. E291-A1 29" 720p LED-LCD TV -...
When changing channels sometimes I lose audio
Are you using a cable or sat box. if so I would suspect that device. If your are using the tuner in the tv rescan for channels. be sure you have antenna selected. If problem still occurs replaced the main board .
Jan 06, 2014 | Vizio E390-A1 39" LED TV 1920x1080, 60 Hz,...
Vizio e420 sound problems
1. Press volume up on the remote control. 2. Press the MUTE button on the remote to ensure mute is off.
3. Check the audio connections of external devices (Blu-ray player, game console, cable/satellite box) that are connected to the TV.
4.If you are using an antenna, the signal strength of the channel may be low. Ensure your antenna is connected securely to the TV and move the antenna around the room or close to a window for the best signal.
If you tried the above and still have sound problems, use your menu and check the audio settings to make sure they a right. You may have to reset the audio.
Feb 22, 2013 | Vizio E420i-A1
The sound on my Sanyo AVL262 26'' LCD TV shuts off spontaneously
Go into your menu under Audio and make sure that SAP is off ! Let me know?
Jun 04, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
64 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
