Question about Dryers
Newer Kenmore dryer automatic sensor not working.
Hi, I have a newer Kenmore dryer (model GNSR465EB3WW) and the timed dryer function is working normally but the automatic sensor is not operational. Ie when you put it on automatic, the sensor is not shutting off the dryer when things are dry but it keeps running. Where should I first look to solve this problem
  • hotlrv Apr 18, 2009
    I have a Maytag Neptune Electric Dryer.
    The timed dryer portion works fine, but the automatic temperature does not dry the clothes enough? They are damp when the dryer shuts off.
    What should I look at?
    Problem Solver:
  • 20 Answers
I dont understand your problem?
Posted on Jan 19, 2009
Hi, how do I remove the top panel on the newer model Kenmore electric dryer, model 592-69212? Thanks.
On mine there are screws on the rear top that will disengage the top panel.
Oct 03, 2015 | Kenmore Dryers
How do I change out the heating element on my kenmore oasis electric dryer model 110.67032600
Use a putty knife to press against NUMBER43.
This is a newer cabinet but basically busts down like an older one.f4825eb.jpg9b58516.jpgAfter the front is removed the dryer magically becomes exactly like this older model here: Cabrio dryer service manual. Similar to oasis.
Oct 10, 2010 | Kenmore 67082 Electric Dryer
Dryer turns but we are gettin no heat book said to look for fuses i was wondering where they were located?
On back side of older models885b56b.jpgOn newer models the limits are inside06ad40b.jpgThis video shows how to get into a newer machine
This LINK shows how to get into an older Kenmore dryer
Typical fuses and locations
Aug 16, 2010 | Kenmore Dryers
Push to start switch does not work
That is a bad motor. Run winding is gone. This video shows how to replace it on a newer model:
http://www.youtube.com/watch?v=tm1ZCiAnxto&feature=player_embedded
This video shows how to get to it on older models:
http://www.youtube.com/watch?v=LiXD8euFteQ&feature=player_embedded
Jul 08, 2010 | Kenmore 73952 Gas Dryer
GNSR465EB3WW
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Jan 18, 2010 | Kenmore Dryers
Kenmore gas dryer have replaced coil set and
Could be a bad flame sensor, or a bad thermostat. If it is a newer model with a thermal fuse, it could also be bad. Then there is the timer too, but that's not usually suspect. What model is it?
Jan 07, 2010 | Kenmore Dryers
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
I have a kenmore electric dryer. It dries for about 20 minutes then stops. If you wait for about 10 minutes and start it back up it continues to dry again.
Hello There,
1st- Check to see if your not running on overload with a clogged dryer hose the one that goes outside
2nd- your timer may be going bad or you have a bad sensor thats resetting itself.
Is this a newer model???? What year and model number?
Apr 02, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 84152
On a kenmore conventional dryer they had for a million years the heating element is on the rear of the machine on the right. Some newer models "princess type" have a lower front panel and a heater that just yanks out for easier servicing.
Jan 20, 2009 | Kenmore 84152 Electric Dryer
Dryers Logo
501 people viewed this question
Top Dryers Experts
