Lg tv rt-29fe55vp service mode
RT-29FE55VP
zjut
  • 106 Answers
SOURCE: LG 42INCH PLASMA TV BLANK SCREEN
Open the back cover and check the fuses on Y Sus Board and X Sus Board. If you can find a blown fuse, just replace that board and your problem will be fixed.
Posted on Feb 23, 2008
  • 22 Answers
SOURCE: LG RT-42PX10
everyone's lucky day!  follow this link closely!  it will work!  it worked for me on my gateway, which has LG boards.  trust me.
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Posted on Apr 28, 2009
SOURCE: looking for code for synergyv RT-U64CP cable
020 worked for me. Look up the Sony codes and try them as these Sceptre TV's have Sony panels in them.
Posted on Nov 09, 2009
SOURCE: LG Model# RT -42PX11,screen is not working.. shows
My LG RT-42PX11 after a few minutes the screen starts to flicker and colors go psychedelic and after some time no picture at all
Posted on Nov 15, 2009
SOURCE: LG plasma RT-42PX11 Colour went funny and then
LG part 6871QZH033A is what you most likely need.
There's a chance I might be wrong, of course.
But that would be my first guess.
There's a a guy having it REALLY cheap right now on eBay. I'd bit on it if I were you...starting price is like $10 and normal price is more like $70.
If it's not that then the second one is the YSUS board...he likely has that too.
Posted on Jan 13, 2010
Tip
Frigidaire Dishwasher Error Codes and Service Test Mode
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
on Dec 23, 2009 | Dishwashers
No, still cannot get a free instruction manual for LG TV 66cm RT-28FZ10RX
LG RT-28FZ10RX
You can get a manual from;
http://www.ps2netdrivers.net/manual/lg.rt-28fz10rx/
The format is probably in an ADOBE PDF format.
If you do not have an ADOBE reader you can get one from www.getadobe.com
Apr 17, 2011 | LG Televison & Video
Hi, i have an LG plasma, model number RT-42PX11.
You need to pull the power supply out and replace the damaged caps on the board. Look for swollen, pushed up tops and leakage around the base of the caps.
You need soldering and basic electronics skills. You also need to pull apart that big tv and pull the power supply board!
You can look on Ebay for pullout boards from people who have broken their screens. It can get you a working board for cheap sometimes!
Good luck and be careful!
May 07, 2010 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Lg rt 56nz23rb
Hi there.
Replace the stk convergence ics and also the 3.9 0hm fusible resistors.
Sep 20, 2008 | LG RU-52SZ51D 52" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
