Question about Kohler Home
Koehler K4632 Fills promptly, won't shut off unless you "help" the float or arm the last 1/4".
Appears the float is adjustable ? Float is attached to a long screw type arm.
  • 16 Answers
SOURCE: Toilet continues to run. THe plastic float cup
The adjustment is inside. It just needs to be adjusted.
Posted on Jul 10, 2009
bozcro
  • 867 Answers
SOURCE: Just replaced the entire flush assembly because it
you can also bend the float rod gently to get desired float position
Posted on Jul 19, 2009
  • 39 Answers
SOURCE: HEAR DRIPPING FROM AMERICAN STANDARD COMMODE
the one in the center adjusts the shut off level the other one probably locks the ball rod on.If the drip is the tank draining into the bowl replace the flapper
Posted on Aug 05, 2009
  • 119 Answers
SOURCE: how can I adjust the float
what happens is the float is not staying open for long enough, by shorting the chain that goes to the flapper might help but you can only shorten it so much or the flapper does not close all the way then the toilet is just running and running. No you don't want that so the other thing you can do that might work is when you go to flush the toilet just hold the handel down for 5 seconds this will keep the float up and open for the Right amount of time. Other wise the other way to fix it witch is a old school trick is that you need to find a nice small piece of foam, witch floats and is about the size of a old half dollar and as least half inch thick, you place that on the chain that goes to the flapper so when the toilet is flushed the flapper will float and stay open . IF you do this just make sure to use a good piece of foam and secure it properly where it wont come off the chain.
Posted on May 18, 2010
  • 349 Answers
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Posted on Jun 10, 2010
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
Water only dribbles out of lower spray arm during cycle and spray arm doesn't turn. checked filter, water lines etc. If it's a motor or pump that needs to be replaced, how do I get to it?
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Sep 03, 2011 | Bosch Dishwashers
Dishwasher won't fill with water
Hi
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Dishes just aren't getting clean...bottom or top rack
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Frigidaire Dishwashers
My Model is Kitchen Aid Dish washer KudS01DL. Water inlet and outlet are working well. I do not here the water being sprayed. Only here a straining pump. The srpay arms are barely spinning when I open...
Yes their is a filter in the pump..this vodeo will show ya how to take apart the pump and clean the fitler..sorry the beginning of the video is a bit cheeesy but when they get to how to part the info is solid!
Aug 23, 2011 | KitchenAid 24 in. KUDS01DLSS Built-in...
Dishwasher comes on but it won't fill.
Hi
Daniel
Aug 21, 2011 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
The dishes on the top are not getting clean. Wondering if there is something wrong with the top spray arm or ultra flow water feed tube.
Hi
Daniel
Aug 07, 2011 | Kenmore Dishwashers
Ishes don't come clean in dishwasher
Hi
Daniel
Aug 05, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
Unit won't fill with water
Hi
Daniel
Aug 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
ESL624 dishwasher. On any cycle the machine stops after about a minute or 2. Its as if it cuts out for some reason, It pumps out but it doesn't get to the point where it starts letting water in....
Hi
Daniel
Jun 28, 2011 | Electrolux 23 in. ESL624 Built-in...
Hissing sound in tank (fill valve) . fills too level line & keeps then slowly fills too top, floats been adjusted .
Dear Sir,
It appears you need to adjust the float level so that it applys more pressure quickly to completely shut off the water going into the main filler tube. Does the hissing go away when you lift up on the float toward the ceiling? If it does, then you need to what I said above. Turn your float ball out farther, or carefully bend your rod down toward the base of the toilet so that it applies more pressure quickly. This should solve your issue.
Cro Dave
Oct 18, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Home Logo
26 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
