Question about LG Televison & Video
Berkshire TV turns on by itself....is there a reset button??
Since installing on wall mount, TV turn on by itself sporadically. Not every day, but ocassionally in the middle of the day or night. What could be causing this, and how do I fix it. Right now I unplug it every night before bed. Any other suggestions???
SOURCE: I have a a insignia lcd tv model ns-27lcd turns off by itself
check timer it may be set it will continue until its turned off
Posted on Sep 17, 2007
centralhigh
  • 260 Answers
SOURCE: TV turns on, then immediately off again
hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
Posted on Jun 22, 2008
dsacco86
  • 1077 Answers
SOURCE: Panasonic Viera 46" plasma~no sound, no picture
I would use the warranty at Bestbuy at that point. Opening up the TV would most likely void the warranty.
Posted on Jun 28, 2009
jennerina
  • 86 Answers
SOURCE: Proview LCD TV is turning itself off inconsistently.
I don't know about your particular tv, but most of the LCD tv's have a power off option that it will turn off after 3 hours of no activity.
Why it would turn itself off at 3 and 30 minutes is beyond me. But I did want to write so you can check your settings to see if maybe someone has programmed in some shutdown times or something.
Hope this helps at least some. Good luck!
Posted on Jul 31, 2009
stonephoenix
  • 563 Answers
SOURCE: when i turn on my samsung lnt5271 the screen seems
This sounds like a repair issue. I do not believe there is any in-home troubleshooting that you can try that will fix that particular issue. I would call Samsung tech support to see what their opinion of the problem is. Their number is 800-726-7864.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
Tv won't come on tried all the trouble shooting ideas in book but nada
hi if you brought the tv in november might best to get in contact where you got it from ask them to send a tech out, you won't have to pay as it should be covered by the warranty good luck
regards
shaun
Jan 23, 2014 | Universal 40-42 Inch Flat Screen Panel...
We have a DLP-Wide Screen TV purchased in 2004. Just recently it began "turning itself off". It does it sporadically, but quite often during the day. Does it when cold or warm. We had our...
Sir did you replace the lamp, if you replace the lamp you should reset the lamp hour meter. Feel free to send feed back good day and best regards.
Aug 22, 2011 | Samsung Televison & Video
My Sony Grand WEGA LCD rear projection 51" turns itself OFF every 20 sek and turns itself back ON after every 35 sek. ???
Try resetting the TV to the factory settings. Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Sony Televison & Video
TV says lost signal and turns itself off
Unplug the TV from Wall, wait a bit and plug back in. Should be reset.
Feb 09, 2010 | Vizio L42HDTV 42 in. LCD Television
Works fine but turns off Sporadically
seems like the tv power supply is having some issues.. you might want to try leaving the television unplug over night.. and turn it on the next day .. if the tv still turns off by it self then try plug in the tv straight to the wall or try a power strip if the problem is still there.. then the television's power supply will have to be replace or repair..
There is a 3rd party repair center that is able to service Olevia televisions.. the service center is called Amergence Technology 866-965-3842 they could get you a repair quote..
Jul 12, 2009 | Syntax-Brillian Olevia 252TFHD 52 in. LCD...
TV changes channels/volume/source by itself
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jun 16, 2017 | Televison & Video
Television volume keeps turning up and tv turns on by itself
Good Day, OkieDi;
Try resetting the TV and/ or Boxes, to reset unplug devices from the A/C wall outlet, for 3 to 5 minutes then plug all back into wall again.
Good Luck, big IRISH PS. or call a preist or an Authorized Service Center, GET estimate.
Aug 30, 2008 | Televison & Video
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Televison & Video Logo
168 people viewed this question
Computer Repairing
Computer Repairing
