Question about Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher
Will not start
The lights come on but no movement. then lights go out.
I have the same problem and it turns out that it is the front panel touch pad that cost $185 for the part. I plan to just buy a new washer.
Posted on Jun 23, 2009
Do not buy a maytag product. They make junk.
Posted on Oct 19, 2010
New batteries control lights up no movement. Help
Presuming the watch and the battery are both in working order there is only two things it could be:
1. (Unlikely) the battery is incorrectly fitted i.e. wrong way up.
2. (Very likely) the movement on the watch will have two points which have to be shorted out (Joined) momentarily in order for the movement to start, they should be marked on the movement, further advice not posible due to so many movement variations.
Feb 21, 2017 | Watches
Hi, My Saeco Vienna isn't working so great. When I start it up, it makes no brew-group movements and the red light goes on, as well as the water light. Both are displaying solid lights. it won't go in
If every component is in it's correct position and the brew group makes no or very little movement upon start up, it means the 33v DC converter on the CPU is probably bad and the board will need to be replaced. Or, one of the microswitches in the gearbox could also be broken or malfunctioning. Either way, with the symptoms you've described, I believe you will need to have the machine serviced by a Saeco Certified technician. The repair should cost between $175 - $225 unless there are multiple issues.
Dec 08, 2014 | Saeco Vienna De Luxe Espresso Machine
Fault 16 light 00010 000
Your motor controller board is faulty and has no motor movement.
Mar 29, 2014 | Fisher Paykel Eco IWL16
Ford 601 tractor starting problems
Ok lets start at the start on this one. Which of the following best describes the situation?
- Turn key and nothing, no lights on dash, no noises.
- Turn Key and weak lights that flicker in start position and clicking noises
-Turn key, strong lights but little to no movement from engine or a strange noise comes when key is turned
-Turn key, strong lights, engine turns over but will not fire.
A tractor is a complex piece of machinery and something like an engine that will not start could indicate one of many problems, with some trial and error you can generally work out what the problem is be we need somewhere to start.
Aug 03, 2013 | Garden
Unlock
Not enough info to really give a good suggestion. Flashing lights and no movement usually indicates that the batteries are very low. Testing the batteries is the place to start and go from there.
Apr 29, 2013 | Pride Jazzy Select 6 Indoor Power...
Frigidaire LTF2140ES2 stopped working. Door locks then nothing...no water no drum movement just nothing but a hum, them it shuts off
I is this all the time on the LTF2140ES2 models. You will need to replace the door lock assembly. They fail quite often and cause the problem you are having.
Here is a link to the art you need
Oct 13, 2012 | Washing Machines
I have a Jazzy1113,it had been unused for several years.I did not take right steps to take care of batteries. I tryed several months ago to start and of course would not,but i do remember some movement...
There is a 7.5 Amp ATO automotive fuse on the rear electronics tray that is probably burnt out. The ammeter will not work when this happens. Also, if you have a bad on-board charger that will inhibit movement of the chair. Unplug the on-board charger and see if you get it to move. Hope this helps.
Jan 04, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Door ajar light & chime go off while driving.
Could be as simple as enough body movement to trip one. Find the buttons on the door posts & put something on them like masking tape (few layers) where those buttons or levers touch the door, and see if that helps, then start removing it one door at a time. And/Or, push in on the doors with some force & see which one has the most movement, the one that does, may be your culprit.
Apr 04, 2009 | 2005 Dodge Ram 1500
Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher Logo
610 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
