Question about Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer
Keeps saying no paper Makes loud clicking noise
Keeps saying no paper and makes a loud clicking sound
  • 2 more comments
  • Anonymous Mar 05, 2009
    keeps saying no paper Makes loud clicking noise"
  • decenaplaste Mar 05, 2009
    Having the same problem, says out of paer and makes a loud clicking noise.
  • muddmanch Mar 06, 2009
    I found that if I have only a few pieces of paper in the paper tray it won't make the noise, and I can use the bypass tray instead.
  • sales668 May 01, 2009
    we are having the same issue. cannot print from the tray at all.
The clicking sounds seems to be made by the small gears on the side of the tray. When you move the gears, it should push a plate beneath the paper upwards, and the paper with it, allowing the paper to be feed.
I'm not sure what I did to fix it. I removed the paper and cleaned both feeding rectangles (to the front of the tray -- nearest you). One is underneath the paper and the other is in the front, center.
I then made sure that, when I move the biggest gear (the one that isn't round) that the paper moves upwards.
Posted on Sep 01, 2009
  • Captain Ford Sep 26, 2010
    I had the exact same problem, and for me at least, the problem was the tray being too tight for the paper. The only change I made was adjusting the back of the tray to fit the paper. When I tried it again with the tray too tight, the problem returned.
My CanonPC940 won't grab paper and push it through to print-also makes a a loud "grinding" noise. How can I fix this?
Sounds like a tire may have slid off of a wheel. Yes they have wheels. Also paper soaks up water like a sponge always keep your paper in the wrapper it comes in and the top side of the paper is where the seam is. Make sure you put the paper in so that the top side is the side going through the machine. I do how ever believe you have a wheel or gear out of place.
Oct 15, 2015 | Canon Office Equipment & Supplies
Keep getting out of paper error and paper wont feed makes loud grinding noise
A screw or something else is in the printer not allowing the gear to move freely.
Apr 22, 2015 | HP C6280 Photosmart All-in-One Printer...
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
The printer says "paper Jam" but no paper is in it. When ever i click "ok" it makes a loud noise and says "please wait" but it doesnt do anything. What do i do?
Dont worry about that. Try to visit this website this website it will help you to solve that paper Jam kodak.com/go/stepbystep
Nov 19, 2009 | Kodak ESP 5 Printer
Weird noise from printer carriage
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper. If nothing is found, then likely a hardware error exists.
hope this helps!
Aug 31, 2009 | HP Photosmart 3180 All-In-One Printer
Hp psc 2210 printer jam
your printer need to be opened and check for any lever is struck or dislodge, it will be better if you send it for servicing
May 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer makes extremely loud clicking noise
http://printer.konicaminolta.com/support/current_printers/mc2430dl_sup.htm#Printer_Specific_Documentation The user guide should be helpful to you to pinpoint what is causing the noise. Sounds like the belt drive or gears may be having a problem. Let me know what happens. Tim
Mar 06, 2007 | Konica Minolta magicolor 2430 DL Laser...
Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer Logo
1,157 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
