Question about Panasonic KX-T7730 Corded Phone
Speed dial for panasonic kt-t7730
cnavarro
  • 2460 Answers
SOURCE: Panasonic KX-T7730- assigning speed dialing/one
It says "Not Stored" because you haven't stored anything in it. There are 12 buttons on the left side with lights and 12 buttons for feature dialing on the right. If you want to monitor extensions, the buttons on the left are the ones to use. If you want to store speed dial numbers and feature codes use the ones on the right.
Left button programming. Press PROGRAM and the button. For extensions, dial 1+ext and STORE. For CO's, press 0+line number, for inside codes press 2+code, for outside number press 2+9+number, all followed by STORE.
Right button programming. For inside codes dial the code, for outside number press 9+number followed by STORE.
Note that you could also dial "8x" or "80x" in place of "9" for specific line access. Also, you can store extension speed dial numbers on the right, you just won't get a light indication when they're busy.
Carl
Posted on Jun 04, 2009
cnavarro
  • 2460 Answers
SOURCE: Panasonic KX-T7730 Speed Dials - Please Help!
So I guess that means you're not programming SYSTEM speed dial numbers. Those are programmed from the system manager or operator's station. Personal speed dials are 1-0 and are programmed per set.
Carl
Posted on Sep 03, 2009
cnavarro
  • 2460 Answers
SOURCE: I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
Posted on Nov 09, 2009
SOURCE: how do i delete speed dials on panasonic kx-t7730
since panasonic kx-t7730 does not have a delete option
we can however replace the number to a another number or a dummy number as per the model
KX-TA624 ....PRESS 2 *
KX-TA1232...PRESS 3 0
.... TYPE DESIRED NUMBER(eg: 0000)
AND HANDUP
This would replace the existing number
tell me if this works
Posted on Feb 24, 2010
Phonesmith
  • 113 Answers
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
Posted on Mar 24, 2010
I have a panasonic KT-T7730 instrument & no EPABX... how can i directly connect it on telephone line. Pls help...
Just plug it in. Nothing happens? Oh, guess not. You have to have a SYSTEM to use it.
Carl
Jun 15, 2011 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone programmed speed dial numbers not working. will not dial numbers programmed
When the system is installed, you need to make sure that only the lines equipped are in the access plan (program 400 in a TA series box). When you go to the intercom on a phone and dial "9" you should get an outside line every time. If that works, system and personal speed dials include that access code as part of the number. eg my test number is 914197845522 9+1+10 digits.
Carl
Apr 01, 2011 | Panasonic KX-T7730 Corded Phone
How to set speed dial on panasonic kx-t7730
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00.
3. Enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial.
4. Press AUTO DIAL / STORE to save your setting.
5. To go to the next speeddial location press SP-PHONE and follow steps 3 and 4 again.
6. Press PROGRAM to exit program mode.
7. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
Apr 12, 2010 | Panasonic KX-T7730 Corded Phone
Carl
Nov 09, 2009 | Panasonic KX-T7730 Corded Phone
Thank you.
Sep 14, 2009 | Panasonic KX-T7730 Corded Phone
Having trouble entering speed dials - please help!
Not knowing the specific model of the phone system itself (the PBX cabinet in the telephone closet) I would guess you are using the "personal directory" and it only has 10 number memory and it goes from 0-9. The system directory will give you more mems.
Sep 03, 2009 | Panasonic KX-T7730 Corded Phone
Carl
Sep 02, 2009 | Panasonic KX-T7730 Corded Phone
How to store numbers for speed dialling on Panasonic KX-T7730 having only 12 CO buttons.
Well let's see. You have 12 CO buttons and 12 PF buttons, and at least 100 system speed dial numbers available.
Which ones are you looking for?
Depending on what Panasonic system you're connected to, the PF buttons program by pressing PROGRAM and the button, and dialing the number with a "9" or trunk access code in front of it then STORE. If you're connected to a TD system it's PROGRAM 99.
System speed dial numbers are entered from the main or manager's phone under system program 001.
Carl
Jun 28, 2009 | Panasonic KX-T7730 Corded Phone
Programming numbers into telephone
to store a speed dial on the kx-t7730 with the Advanced Hybrid System KX-TA624 you press the following keys
<pick up the receiver>
<the number you want to have as speed dial>
<the number you want to dial>
<press the square shaped key next to 0 and 9>
<wait for dial tone to return>
<hang up>
To call using the now saved speed dial, press the square shaped key and then the number you have saved to speed dial
For example
<pick up receiver> 2*1555555555<square key> <wait for dial tone> <hang up>
This will mean that when you press the square key and 1, it will dial 555555555
Oct 03, 2007 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
21 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
