Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
January 2006 we purchased GE Profile model PSC23SGRD SS, Serial Nr. ZH408643. So far it worked fine. Currently the cube ice dispenser got gloged and stop dispensing ice. Could you suggest a solution, or email us trouble shooting manual. We counld not locate original manual. Regards,- Jonas Jurasas.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 144 Answers
I believe this is the manual in PDF form that you are looking for. http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60414.pdf
Good luck with your problem.
Sincerely, cbr2009
Posted on Jul 02, 2009
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Both Freezer and refrigerator are not as cold as they should be
We may need to look at the control circuit board the back of refrigerator if the refrigerator has stopped cooling. Let me know if the compressor is running or not. Let me know, I have a repair manual if you like.
Thanks, Sea Breeze
Apr 21, 2009 | GE Profile CustomStyle¿ 22.6 Cu. Ft....
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
177 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
