Question about Zanussi ZHQ575 Electric Double Oven
Zanussi 7700x help
I have replaced my element in my Zanussi 7700x model. I had to remove the back cover as it was to difficult to do from inside. But just as I am about to put the back cover on after finishing the jobI, Ive spotted a green wire hanging and not connected to anything. It does have one of the connecter attached tho the end so I presume it goes somewhere. can anyone help me.
  • Zanussi Master
  • 3,463 Answers
If you try the oven ,and everything seems to work o/k, then I would conclude that it is an earth wire that is disconnected.
In itself it will not effect the oven , but it does need to be connected to a convenient earth point or ground as it is sometimes called.
If the oven or one of it's functions does not work, then it is obviously anwire that controls something.
Plz rate my comments.
Thanks,
Posted on Jan 20, 2009
Do you have to pull the full oven out to replace the grill element on a Zanussi ZDF490
you usually have to remove a couple screws from the back panel to get to the element and in others u can remove it from within if u look inside u should be able to see if it has a screw holding it. and the connecting plugs can be removed from the element
Mar 11, 2015 | Zanussi ZDF490 Electric Double Oven
The element has blown on my Zanussi ZBF860 oven. I
You should be able to remove the element without removing the oven. Open the door and remove the back panel, normally 4 screws. This will expose the element. Then it should be 3 or so screws holding the element to the frame, remove these and slowly pull the element towards you carefully, then remove the 2 wires from behind and make sure they don't fall back into the oven as you will need to remove the back panel to get them. Then reverse process to install new element. Hope this helps.
Mar 15, 2011 | Zanussi ZBF360 Electric Single Oven
I have a zanussi built in oven model no zbf 860b which the fan is still working but the oven is no longer heating up?? Thanks
If the red light is coming on when you turn on the oven control then the thermostat is ok.You will need to remove the grids from inside the oven then remove the inside rear panel 4 screws, be carreful not to damage the thermostat as you remove the panel.When you have removed panel you will see the ring element,now remove the 3 screws holding in the element and gently pull it towards you,remove the 2 cables off element but do not let them fall into the back of cooker or you will have to remove the cooker and gain access to the rear of the cooker.Once you have element check with a multi-meter for continuity and replace if blown. Relacement is a reverse of removal.
Hope this helps.
Aug 04, 2010 | Zanussi Ovens
Zanussi built in oven and grill the element has gone but dont know how to get element out to replace any ideas thanks
If you mean the fan element then take all the racks out of oven and at the back is a panel with 4 screws remove may need a tap with hammer and screwdriver to shock rust etc. then undo screws on element maybe 3 screws pull gently forward(electric off).Try to pull the spade connectors off without losing them into back of oven if you lose them then you will have to take out oven and remove back plate. refit new element.If it was the grill element just follow above and find behind back plate.Hope I helped.
Apr 11, 2010 | Zanussi ZBF360X Electric Single Oven
Bottom oven not heating up
If it is a fan assisted electric oven and the fan is working o/k, and the temp indicator lamp is lit, then you need to replace the oven element, located at rear of oven compartment behind removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Zanussi Ovens
Fan not working
Hi, its likely that the fan motor isn't working. (most times is just build up of grease) If you're good with DIY, remove the inside panel that covers the element and the fan, undo he nut CLOCKWISE, pull the oven out, remove the the back cover, remove wiring from fan motor, clean the motor with WD40, and give it a few turns to see if turns freely. Reserve the process.
Cheers
Feb 07, 2009 | Zanussi ZBF360 Electric Single Oven
Main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Jan 06, 2009 | Zanussi Ovens
I want to replace the top grill element in a zanussi zhq 575
Regardless of wether it is built in or free standing you will have to remove the rear panel, possibly the top cover as well.
The element may be fastened from the inside of the oven .or on the outside at the rear, depending on which way the screws have been fixed.
Undo the fixing screws, disconnect the wires taking note of the connections ,this is very important, and withdraw the element from inside the oven.
Fit new element in reverse order, it is a fairly straight forward repair to do..
Plz rate my solution.Thanks.
Jan 03, 2009 | Zanussi ZHQ575 Electric Double Oven
Main oven wont work
It is the oven element that has failed
Remove panel at rear of oven compartment, there you will see the element, just undo any screws that you can see and pull the element towards you, carefully detach the wires, but don't loose them inside or you will have remove the oven to get the wires back on.
Fit new element and Bob's your uncle ,you've cracked it.
Plz leave feedback for this solution.
Thanks.
Dec 13, 2008 | Zanussi Ovens
Zanussi oven not heating
The fan element was not working, bought one on ebay replaced it works ok now. Fairly easy to fix remove inside back cover, 4 screws, you will see the element remove 3 screws pull out element pull off 2 connectors careful not to lose the wires back through the holes. replace in reverse order.
Jul 12, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi ZHQ575 Electric Double Oven Logo
208 people viewed this question
Top Zanussi Ovens Experts
ashburton
marley mcelhinney
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
