Question about Air Tools & Compressors
Husky- air compressor -regulator - Air Tools & Compressors
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Mastertoolrepair.com has some Husky parts.
Posted on Jan 04, 2013
RCtech
  • 55 Answers
SOURCE: manual for husky air compressor ''easy to go''
For what it's worth Compressors are intended to be turned on and forgot (except for the noise). just for grins lets assume you have the stapler and air hose. you need to hook up the air hose to the compressor there usually is one or to either couplers or npt fittings (threaded). attach the hose to the compressor and using a quick coupler (prefered because it allows the gun to swivel) connect the gun to the hose. turn on the compressor and wait for it to build up pressure and *******. at this point you will need to locate the regulator on the compressor. it will be a knob next to one or two dial gages. crank the regulator a quarter turn either direction while watching the gages. It (one of them) moved either up or down . now you know how the regulator works and your almost a contractor. on to the stapler, load it and find a bit of scrap (what your working on would be best.) now shoot a staple into something and see if it goes in far enough or to far. adjust the regulator to compensate. do this until one of three things happens A you find the right staple depth B the compressor kicks on again, wait for it to turn off C you run out of nails, beer or intrest in the project. once you have found the correct pressure for your needs. you may fire at will you don't need to wait for the compressor to cycle while running the stapler just during set up. now your a contractor go have a beer.
just a last tip if you find you don't have the correct couplers home depot, harbor freight or amazon (online) are great sources for parts.
good luck and mind your fingers
Rob
Posted on Dec 10, 2008
brewerstool
  • 141 Answers
SOURCE: how do i repair a broken air regulator on a husky portable air
You will have to repalce the air regulator. Campbell Hausfeld is the maker of the Husky air compressors. There should be a different model number on your compressor that you can use to locate the part number on the chpower.com website. The only problem that I have come into is that the parts are not available for these models on a long term basis, and they may not offer any repair parts at all. If you can not locate the part on the Campbell Hausfeld site call Home Depot and ask them where you can get the part.
Posted on Sep 09, 2009
  • 18 Answers
SOURCE: my husky air compressor is suppose to shut off at at 125psi
Pressure switch may be stuck. May need to adjust pressure switch.
Posted on Jul 10, 2010
  • 1388 Answers
SOURCE: How do you replace the regulator valve on a husky
I could not find parts for my husky compressor and had the same problem as you describe. I went to lowes and purchased fittings to draw air out of the safety port. Remove the safety pop valve and install t-fittings to allow you to reinstall safety valve and also a quick connect. If you want to be able to regulate the pressure, install a simple pressure regulator before the quick connect (also avail. at lowes). This remedy is not pretty but sure works great and simple. Problem with husky regulator is stripped thread /knob. Sometimes you can turn the knob if you drain air from tank; this will release the spring tension on the regulator knob.
Posted on Jan 01, 2011
  • 492 Answers
SOURCE: Husky 6 gal 1.5 hp
if its not the line busted or leaking then the diaphragm in the regulator is busted
Posted on Jan 21, 2011
Husky air compressor repair
Are you meaning that you cannot adjust the regulator to change the pressure output?
Jun 01, 2013 | Husky Factory Reconditioned Electric Air...
Compressor reaches 125 psi but does not shut down
Depending on how old your compressor is, usually inside the pressure regulator cover are instructions on how to adjust the turn-on and shut-off pressures. If not, it usually invloves turning a nut or screw to lessen the pressure on the spring that keeps the contacts closed. Try adjusting the pressure down. If it won't come down to a safe level you will be better off replacing the pressure switch. The number you give above is the Campbell-Hausfeld (they are Husky) part number for the pump and motor assembly so I don't know which CH pressure regulator you need. They are easy to find and easy to replace.
Jun 21, 2012 | Square D 9013FHG14J52M1X Air Compressor...
How do you replace the regulator valve on a husky pancake air compressor? Mine just spins and will not allow me to get air to the hose
Dec 31, 2010 | Electric Air Tools & Compressors
How do I tighten the pipe on to the air regulator and the husky 26 gallon tank at the same time? they all need to be turned the same way, I do not understand
This can be a tricky dominoe affect depending whats in the way when you make a complete revolution while turning. Take everything off. If possible screw the pipe into the regulator first, then the pipe and regulator into the tank. If you are not getting the desired postion or alignment when you tighten it, then you will need to apply a few layers of teflon around the thread to achieve proper location.
Dec 05, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Got a Husky 6 gal pancake, 1.5hp. motor runs- no air pressure ??
the regulator may be turned down, find the regulator turn it to the right to allow air into the tank, tank must have air in it to deliver air
Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
How do i repair a broken air regulator on a husky portable air
Just to add to the posted advice which would have prevented the repair I'm having to make and the things I'm learning the hard way as I'm fixing the stripped regulator on my H1826F from 2008...
here's the damage:
Other thing that was tricky is getting the cover off the top to get at the guts - most of the holes held screws - easy to get off, but the bottom holes were tricky as the bolts are so far in it's hard to tell what you are dealing with... here's what I found after I broke things (gotta love superglue - it's all better now):
once you get the bolts turning, loosen them till the cover will pull apart and you'll get them both off in one piece, threads intact.
Sep 09, 2009 | Air Tools & Compressors
I have a Husky model Y6010 air compressor.
First remove the valve using probably about a 1/2" wrench but make sure there is no pressure in the tank before you do so. check the cone and seal by loosening the valve by hand and check for debris. If there is no debris then the problem is either the pressure relief valve or weak pressure regulator but may also be a bad piston seal if it is a direct drive unit.
Apr 28, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
150 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
