Question about Candy CNW136 Front Load Washer/Dryer
Programme Slector keeps on turning after each wash eg. if I slect programme 4 after it finish 4 dile will keep on doing a full circle.
Need a new timer....that is the thing u turn to select wash cycle. dont even take this out to try to fix it...for it is packed full tight and many gears...one is bad at least. now u can get to timer with screwdrivers maybe a 5/16 socket too ...if a plug of wires goes to it...dissconect the timer plug..pull the timer write down any numbers you see and go online with make and model to find a new timer. or call a appliance repairman. the timer might be cheap. also many appliance stores have timers. CrazyLarry
Posted on Jun 27, 2007
I have a bosch logicxx 7 washing machine. I've
Suggestion: Keep the beep button pressed or keep pressing till the beep indicates 'off'.
Mar 24, 2013 | Washing Machines
The spinning cycle is very noisy and the clothes are still very wet when programme is finished.
Sounds like the belt may be slipping and the spin is not running at full speed. Try spinning with a light load and see if it can keep up. If not you may be able to adjust the belt or it may need a new belt.
Mar 16, 2011 | Whirlpool Washing Machines
How to release child lock in seimens washing machine that is wash and dry D12-52 1200 rpm
Child lock will deactivate only in the original programme that it was activated in. If you have forgotten the orginal programme, try deactivating separately in each programme.
To deactivate child lock press the clock key for 5 seconds.
Nov 07, 2010 | Siemens WFXD8400UC Front Load Washer
Washing programme keeps stalling
Ok, this is a basic control fault within the logic chip set. you will need to replace this faulty control board/timer in this case.the replacement of the control/timer will fix this issue.
Jun 01, 2009 | Electrolux Washing Machines
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
Washer/dryer
open the filter on the bottom of the machine (water will empty out).  Clear any blockage.
Oct 07, 2007 | Ariston Technologies Ariston AWD12 Front...
Candy CNW136 Front Load Washer/Dryer Logo
69 people viewed this question
Top Candy Washing Machines Experts
Marvin
Marvin
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
