Question about Tricity Bendix TM310W Electric Dryer
Tricity Bendix Condensor Dryer
Im trying to attach the belt to a tricity bendix condensor dryer. It seems to be too big but it is the right belt
  • Anonymous Feb 09, 2009
    BELT SEEMS TO BIG
  • dgf74 Apr 11, 2009
    i have same problem belt seems to big
    Problem Solver:
The belt needs to go over motor rod first this means you have to take cover off then release the spring that attached to the motor so there is some play with the belt ,then pull the belt around the drum,quiet tight but you can do it,then pull the motor spring back into position to tigthten the belt put back together.... job done
Posted on Apr 11, 2009
Tricity bendix tm 550 motor spring adjustment
If there is no provision for adjustment, the spring may have lost its tension and will have to be replaced.
Nov 18, 2016 | Tricity Bendix Dryers
How do I replace a belt on a tricity bendix TM221W tumble dryer - a video of this would help. thanks.
no video
unplug it
you have to take the top and back panel off
take photos of how the belt is fitted before removal
see what holds the belt on or stops it from coming off
undo what is required and fit the new belt
then reverse all the take apart steps till it is fitted
Tricity Bendix TM221W 91609308601 Tumble Dryer Functional parts Spare...
Dec 26, 2014 | Tricity Bendix Dryers
How to fit belt on a tricity bendix tm310w tumble dryer
round the pulley then around the tensioner then around the drum.
Jun 08, 2014 | Tricity Bendix TM310W Electric Dryer
My tricity bendix dryer TM 320W is heating up but it's takeing at least 3 full cycles to dry the clothes and the water tank is hardly ever full, whereas i had to empty it after ever few loads before. any...
check the condensor is clean.the most overlooked reason for this is failure of either the seals at the front and rear of the drum allowing the closed cicuit heated air and there condensing air mixing. check the seals its usually the rear one.
Aug 04, 2010 | Tricity Bendix TM310W Electric Dryer
Manual for bendix consorte DN550
Belt & Pulley drawing for Tricity Bendix TM220W Dryer
May 03, 2010 | Tricity Bendix Dryers
Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Jan 30, 2010 | Tricity Bendix TM310W Electric Dryer
Tricity Condenser drier
clean the condensor itself
Sep 09, 2008 | Tricity Bendix Dryers
Tricity Bendix TM310W Electric Dryer Logo
331 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
