Question about Epson TM T88 Thermal Printer
Epson Thermal Printer does not print clearly - Epson TM T88 Thermal Printer
    New Friend:
Dont scaning canon pixma mp250 error coad is
2,140,2
Posted on Jan 04, 2013
Basti
  • 1447 Answers
SOURCE: How to make Epson thermal printer print darker?
Change the dip switches settings to
PLS DONT FORGET TO RATE AS FIXYA, THANKS!!
Posted on Apr 25, 2008
SOURCE: Epson TM-T90 thermal printer
your print driver is printing in graphics mode or in reduction mode. disable print spooling, disable A4 reduction or use a faster driver like the epson advanced driver or my fav the generic text only (super fast)
Posted on Nov 09, 2007
Nitrotrike
  • 589 Answers
SOURCE: Epson TM-T88#P thermal printer driver for windoze vista
You can use windows 2000 drivers on Vista for this printer, according to this article:
http://www.prophetline.com/node/141
Posted on Jan 14, 2008
Autodarwin
  • 54 Answers
SOURCE: printing blank receipt every time cash drawer opens
I would try a complete reinstall to make sure the presets of the machine are correct.
Posted on May 27, 2010
HansPP
  • 2510 Answers
SOURCE: epson thermal printer is printing very faint
Carefully clean the thermal head with an alcohol based solvent and remove any build up of any sort that would prevent heat from getting to the paper.
Posted on Feb 28, 2011
Will not print longer receipts. How do I fix this problem
PDF]TM-T70II Brochure - Epson
www.epson.com/alf_upload/pos/pdfs/.../brochure_tm-t70ii.pdf
EpsonThe TM-T70II prints receipts and graphics at the same fast ... Print technology, the TM-T70II can print ... It also offers Serial, Ethernet and USB options ... long-lasting autocutter and all-front access. ... are easy to use and do not affect print ... Space-Saving Thermal Printer with Easy All-Front Access ... Epson Dark Gray (EDG).
Epson C31CD38A9971 TM-T70II Front-Access Thermal ...
www.newegg.com > ... > Receipt Printer > Epson America
Newegg(Do not use your browser's "Refresh" button). ...... Streamline your POS system withEpson's space-saving TM-T70II printer. ... Ethernet and USB options, enabling flexible mobile and web-based receipt printing. ... including drop-in paper loading, long-lasting autocutter and all-front access. ... Color, Epson Dark Gray (EDG).
Epson TM-T70II Series - Epson
www.epson.co.uk > Home > Retail
EpsonEpson TM-T70II thermal receipt printer for barcode, ticket printing is for ... The latest innovation in Epson's long line of receipt printers are its series of smart ... same
Jan 27, 2016 | Epson T70II - SPACE-SAVING - PUSB & USB -...
How do i change the ink
The Epson TM-T88III is a thermal printer so it does not use ink, it prints on special thermal paper only. Be sure you have the correct paper in the unit. If it is correct and the printer still does not print then you have a problem with the print head and the printer will need to go in for service.
Sep 25, 2012 | Epson TM-T88III Thermal Printer
Printer print blank print is blank
its a thermal printer.... which may have defects already.... when the printer prints blank its either its not heating up or the thermal mechanism is already damaged... try calling epson tech support... i think they have a warranty offer for your type of issue since its a POS system. hope this helps you with your issue. :-)
Aug 11, 2011 | Epson TM L60II Printer
Does epson tm-t88iiip have a ribbon
No. thermal printers do not use ribbons or ink cartridges. They have thermal heads that heat up and use that heat to print on the specially treated, heat sensitive paper rolls. If the printer has stopped printing, check to see if the paper is thermal and loaded correctly (shiny side facing the front when it feeds).
Jul 13, 2010 | Epson TM-T88III Thermal Printer
Printing blank receipt every time cash drawer opens
May 27, 2010 | Epson POS TMT88IV Thermal Receipt Printer
The error light on the Epson TM-T88IV keeps flashing whats wrong with it?
The following is from the Epson Users Manual:
Troubleshooting
No lights on the control panel
Check the power supply cable connections and the power outlet.
ERROR LED on (not flashing) with no printing
If PAPER OUT is on, the roll paper is not installed or is near the end.
If PAPER OUT is off, the printer cover is not closed properly.
ERROR LED flashing with no printing (and no paper jam)
Printing stops if the head overheats and resumes automatically when it cools.
If overheating is not the cause, turn the printer off, and after 10 seconds, back on.
Removing Jammed Paper
CAUTION:
Do not touch the thermal head because it can be very hot after printing.
1. Turn the printer off and press the cover open button.
2. Remove jammed paper, reinstall the roll, and close the cover.
3. If paper is caught in the cutter and you cannot open the printer cover, open
the cutter cover as shown in illustration J.
4. Turn the knob until you see a triangle in the opening. This returns the cutter
blade to the normal position. There is a label near the cutter to assist you. See
illustration K.
5. Close the cutter cover.
6. Open the printer cover and remove the jammed paper.
Cleaning the Thermal Head
CAUTION:
After printing, the thermal head can be very hot. Be careful not to touch it and
to let it cool before you clean it. Do not damage the thermal head by touching
it with your fingers or any hard object.
Turn off the printer, open the printer cover, and clean the thermal elements of the
thermal head with a cotton swab moistened with an alcohol solvent (ethanol, or
IPA).
Epson recommends cleaning the thermal head periodically (generally every
3 months) to maintain receipt print quality.
It sounds like your print head is overheating. Clean as instructed above.
Oct 23, 2009 | Epson TM T88 Thermal Printer
EPSON TM-T88 IV THERMAL
using vb how can i change font size an epson tm88 prints
May 22, 2009 | Epson TM-T88III Thermal Printer
Apr 25, 2008 | Epson TM-T88III Thermal Printer
Jan 30, 2007 | Epson TM T90P Label Printer
Epson TM T88 Thermal Printer Logo
2,209 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
