Question about Magnavox 39MF412B 39" Class LCD 1080p HDTV with Dynamic Contrast
Magnavox LCD tv model 39MF412B/F7 when we change channel the picture goes black but we have sound. We have to turn the tv off and then back on to get picture.
  • Tom M
    Tom M Jan 02, 2014
    I have same model with similar issue. Mine goes to no picture (with audio) when I change channels from low def channel to high def channel. If I cycle through the source selections, it comes back.
4 Suggested Answers
  • 5099 Answers
SOURCE: I have a 42inch magnavox lcd and it has lost the
Since you have the audio, it's probably a backlight or backlight inverter issue if the problem occurs on all sources and the onscreen menus. (The backlight itself usually fades or makes the on-screen image change to pink/red.) With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing. For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. See http://www.lcdparts.net/howto/default.aspx for more information but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx. Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
Unfortunately, I can't give any part numbers. The parts are often shared by multiple makes/models so the part number from your tv is needed.
I hope this helps.
Posted on Mar 26, 2011
UberTechzor
  • 295 Answers
SOURCE: i have a 42 in
You were smart to test the image for burned out backlights! :)
Typically, on a screen this size, the backlight inverter is the first place to look.
I found the part number...
27-D026774 Funai TV Module, backlight inverter, PNF10092, I420H1-16A0, 42MF439BF7
You can by it here...
http://www.tristatemodule.com/p-13231-27-d026774-funai-tv-module-backlight-inverter-pnf10092-i420h1-16a0-42mf439bf7.aspx
Posted on Aug 23, 2011
omecron2001
  • 22 Answers
SOURCE: magnavox 42mf439b/f7, no picture or sound
i have set with same problem in my shop and after troubleshooting i found that the problem is in jack mo dual A91h5mjc. when you plug set in you hear relay and turn on when you push power switch after few sec high voltage supply shuts down making light blink. what they did is separate high and low voltage supply's half one one board half on other to confuse everyone.
Posted on Oct 13, 2012
39MF412B
Try Toms Service Manuals. Saw this on search for that model and the words "service manual" but you can also say "schematic" and maybe find something. You can sometimes buy them online also.
Welcome to the TV Monitor Service Manual Database magnavox 39MF412B F7 problem Badcaps Forums
Jul 12, 2014 | Televison & Video
NO Picture, have sound
Check and replace the back-light inverter board as card basis. Contact any service technician. Gopakumar Gopalan Google
Mar 10, 2014 | Funai Magnavox 26mf301b/f7 26-inch 720p...
Magnavox 39mF412B/F7
When I turned on my TV today all I have is one small picture in the upper left hand corner and it says its in retail mode cannot seem to get it back to normal.
Sep 19, 2012 | Televison & Video
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Black screen
Not good. Make sure you have not blocked cooling to TV. It need s air flow. sounds like overheating
Mar 25, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself sometimes screen goes blank tv unresponsive to remote
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
Jul 08, 2009 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Magnavox 39MF412B 39" Class LCD 1080p HDTV with Dynamic Contrast Logo
192 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
