Question about Oreck Air Purifiers
Why is my Oreck DualMax flashing Truman Cell
On the top it is flashing !Truman Cell
3 Suggested Answers
Gabermrz
  • 31 Answers
SOURCE: I cleaned my oreck xl
This is a common problem with the Air Towers. what needs to be replaced is your power supply. If you turn the tower on silence, and you listen very closely to the base of the tower you should hear like a little zapping or buzzing noise. the only way to get it replaced is to take it to an Authorized Oreck dealer and as long as your machine is still under warranty, 5 years from the purchase date, it will be free of charge.
also when ever you wash the cell you want to make sure its completely dry. let it sit out for at least 12 hours. 24 hour is ideal.
Posted on Sep 19, 2011
  • 4736 Answers
SOURCE: Where can I get replacement
Here is a link to where you may can find what you need. You will need to have the correct model number (not just XL Tower Air Purifier) , to find your mode.
http://www.ereplacementparts.com/oreck-air-purifier-parts-c-130239_130321.html
Hope this helps you find the wiring you need. Thanks for choosing FixYa.
Can you add a prefilter to an oreck truman cell to grab the larger dust particles and decrease the zapping?a humidifier in the room helps but when the furnace is going it can still be often.
it should have a prefilter already on it. they have a screen looking filter that goes on the front of the cell. If you don't have one you need to get one. You should also have a charcoal filter on the back side of the cell, if not then you'll need to get one of those also, the charcoal is for odors and not for filtering dust. Putting any other type of filter in front of the cell will just be turning this into a filter type cleaner and will be defeating the purpose of the reusable Trueman cell. You may as well just buy a different cleaner if you don't mind buying new filters instead of cleaning the cell. I would recommend cleaning the cell every 2 weeks to keep it working properly. This will also keep it from snapping, if yours is snapping it's already too dirty and needs to be cleaned, if it's snapping right after it's cleaned then you have a plate that is arcing in the Trueman Cell, I have posted a fix for the ProSheild Models to stop the cell plates from arcing.
Feb 19, 2015 | Oreck Air Purifiers
A red light flashing with clean filter
bad connection on plates or wires that run along the front of the plates in the cell. If you hear snapping or arcing then its the plates shorting out, look for bent plates and broken wires or loose sagging wires.
Aug 01, 2014 | Oreck XL Professional Air Purifier
I have an Oreck XL that is very noisey, even on the silent run position. How can I gegt it fixed?
The problem may be build-up on the blower wheel. When the Truman cell cover is removed, two screws are visible which secure the cover for the blower. remove them and the cover hinges. Keep opening and it will unhook. Use a stiff brush to remove soil from the blower wheel. The unit can be turned upside down over a trash can or better still, outdoors to remove the excess.
May 27, 2012 | Oreck XL® Air Purifier
Where can I get replacement wires for an oreck truman cell? Seems silly to spend 200 dollars when the only thing wrong is four 29 cent wires does it not?
Sep 19, 2011 | Oreck XL® Tower Air Purifier
I cleaned my oreck xl tower air cleaner and the red light won't go out? Non of the wires are broke on the truman cell
Sep 10, 2011 | Oreck XL® Tower Air Purifier
How do i stop the red lite for the collector cell to stop blinking ?
By changing the Collector Cell. The flashing light is an indication that it needs cleaning.
Here is a link to model you listed above. It has all the information you need, on how to clean the Collector Cell. You can download and print it for future reference.
http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf
Hope this helps you solve the problem.
Mar 21, 2011 | Oreck XL Professional Air Purifier
Order New RCI cell Put it in it come and goes
The reason for flashing or surging or a change of settings is usually a loose component.
1. Make sure all components are inserted firmly and correctly. The RCI cell (honeycomb/UV light) must be seated in both ends and turned firmly, like installing a fluorescent light bulb.
2. The 4" white ceramic/screen plate must be inserted into the tracks, top and bottom. The contact fingers must be pressing firmly on the screen part of the plate.
3. The cord must be inserted firmly into the socket in the back of the machine.
If this does not solve the problem, then the computerized system may be malfunctioning. This is something the company will need to address. Call Vollara (new name for EcoQuest) 800-989-2299 and ask for repairs. They
Jan 13, 2011 | Ecoquest Fresh Air Air Purifier
How to remove the air cell
  1. Turn off unit and unplug it
  2. Along the front edge there should be a thumbscrew, loosen until it is free
  3. Lift front cover from left edge
  4. Pull cell from unit
  5. remove screen from cell, it slides out from the top of the cell
  6. remove odor/ozone absorber, it is clipped into the back edge of the cell
You do not need to be afraid to set the unit on it's back or side, just make certain not to drop it.
May 23, 2010 | Oreck XL Professional Air Purifier
V5 filter replace - how to reset red flashing light?
So after you have replaced the V5 Cell Filter in the IQ Air, here are the steps you'll need to follow in order to reset the filter indicators:
  • At the main menu on the control panel, push the menu button 7 times until you get to the screen that says Replace Filter.
  • At the Replace Filter screen, press and hold the Enter Key until the cursor appears, and is flashing.
  • Press the UP arrow button on the keypad until you get to the V5 Cell Filter.
  • At the V5 Cell Filter screen press the Enter Key to confirm your filter reset selection. This will turn the corresponding filter LED to a flashing red light. IQAir requires that your reconfirm the filter selection to prevent inadvertently resetting the wrong filter. If you chose the wrong filter, press the menu key after pressing the enter the first time to disregard the filter change command.
  • To confirm the filter reset selection, press enter a second time, which will reset the filter life, and reset the filter hours.
You can repeat these instructions for the other two filters on your machine when it's time. Here's a link to the product manual for your IQ Air Health Pro Plus which will give you the same instructions, as well as other maintenance instructions.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/IQAir-healthpro-plus-owners-manual.pdf
I hope that this information was helpful to you. If you were able to reset your filter, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of my repair. This is what really keeps Fixya experts continue leaving free repair solutions. Thank you very much,
Chris J.
GoVacuum
Apr 08, 2010 | IQAir HealthPro Plus Air Purifier
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
Air Purifiers Logo
110 people viewed this question
Top Oreck Air Purifiers Experts
brian kossman
Level 1 Expert
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
