Question about Whirlpool Dryers
Location of thermal fuse on kenmore dryer model #96588210
Were is the thermal fuse locatied and how do i get to it?
InMrFixIt
  • 121 Answers
SOURCE: kenmore model 96284100 dryer
The thermal fuse should be connected to and near the heating element. Check the paper electrical diagram, taped on the inside of the dryer.
InMrFixIt
Posted on Aug 22, 2008
SOURCE: thermal fuse location
where located fuse
Posted on Sep 17, 2008
appldoctom
  • 311 Answers
SOURCE: location of thermal fuse on whirlpool estate gas dryer
if this is a gas dryer and the ignitor is working the thermal fuse is fine.need more info .dose the valve coils make any clicking noisecheck with ohm meter to see if coils open/also is gas on
Posted on Dec 31, 2008
TheMobilian
  • 8220 Answers
SOURCE: location of the thermal fuse on the kenmore gas dryer 80
Posted on Feb 04, 2009
johncaman
  • 201 Answers
SOURCE: how do i test a thermal fuse
A fuse is tested using the continuity or resistance (ohm) setting on a multimeter.
Disconnect the power to the dryer. Disconnect the leads to the fuse. With the meter set on continuity, the meter should beep - if you set to ohms, you should read 0 ohms across the terminals of the fuse. If you read infinity, the fuse is bad.
Posted on Mar 13, 2009
How do l change thermal fuse on Kenmore dryer model 110.88752793
Hello Shelton;
My name is Peter. I am a retired field service appliance technician.
25439664-j5jtgwve0qxm0uckbdimcx40-1-0.jpg Thermal fuse 3399849 trips if the exhaust air leaving the dryer becomes too hot.
Unplug the dryer before installing the thermal fuse. Wear work gloves to protect your hands during this repair.
This Dryer Thermal Fuse part #3399849
This is located in the back of your dryer on your hot air exhaust manifold.
Feb 17, 2015 | Kenmore Dryers
Where is thermal fuse
If your Kenmore dryer has stopped producing heat, chances are the problem lies with the dryer's thermal fuse. A fire-prevention safety device, the thermal fuse is designed to disrupt the flow of electricity to the dryer's heating mechanisms if the dryer temperature reaches a predetermined maximum. Once activated, the thermal fuse must be replaced to restore the heat to your dryer. In Kenmore brand residential dryers, the thermal fuse will be located in one of two places.
Instructions
Front Panel Access
1 Unplug your Kenmore dryer from its power source. Make sure that the appliance is unplugged before proceeding.
2 Use a flathead screwdriver or putty knife to remove the dryer's bottom service panel, sometimes called the toe panel. Slide the screwdriver or putty knife along the top of the toe panel until you've located the toe panel clips. The clips are usually located about four inches in from either side of the service panel. Push down on the toe clips with the screwdriver or putty knife to release. Remove the panel and set it aside.
3 Locate the thermal fuse on your Kenmore dryer. Look for the thermal fuse directly above the dryer's motor; it looks like a white strip with two wires, and is usually mounted off to one side. See Resources for a diagram of thermal components.
Rear Access
4 Disconnect the Kenmore dryer from its power source while locating the thermal fuse.
5 Move the dryer away from the wall so that you can access the back of the appliance.
6 Use a screwdriver to remove the dryer's back panel. Set the panel and loose screws aside until you are ready to replace them.
7 Locate your Kenmore dryer's thermal fuse just above the exhaust port. The thermal fuse looks like a white strip with two connected wires.
Tips & Warnings
Clogged exhaust ports are a common cause of thermal fuse failure. While you've got your Kenmore dryer in pieces, clean out the exhaust ducts to keep it functioning at its best.
Take all proper safety precautions when working with electrical appliances. Make sure that your Kenmore dryer is unplugged before attempting to service it.
Check this link ,if you use Whirlpool Dryers:
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/thermalfuse-dryer-Whirlpool-29inch-electric.html
Thanks
Apr 01, 2012 | Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
No heat
The thermal fuse is located on the blower housing while the thermal cut-off is located on the heater housing. If the dryer is electric, runs but doesn't heat, the thermal fuse is not the problem; otherwise the dryer will not run because the thermal fuse is wired in series with the motor and cuts power to the motor when it fails. The problem could the heating element, high-limit thermostat, thermal cut-off, or cycling thermostat. These components can be found in the blower housing and the heater housing depending on the model of the dryer. Specify the model number of the dryer for a more specific advice.
Apr 12, 2010 | Kenmore 63942 Dryer
I have a Kenmore Adavantage Dryer - Model #110-96588210. Dryer runs but no heat at any temperature setting. I have the toe plate off and looking for the thermal fuse that is connected to two blue wires...
the only way you can check if it is ok is to use a tester or continuity tester, it should have a resistance when you check it. you cannot just concluded by just looking at it, fuse are pretty quite decieving.
Nov 08, 2009 | Kenmore Dryers
I can't locate the thermal fuse on my kenmore 64612 dryer. Can you tell me where it is?
64612 is not a good model number however on most electric dryers the thermal fuse is located near the heating element and heat limit switch.
Mar 26, 2009 | Kenmore 64612 Electric Dryer
Fuses
We have Kenmore Elec Dryer - Model # 8860293, 70 Series. Where is the thermal fuse located? Dryer starts and shuts off in less than 5 seconds.
lantzer@hotmail.com
Mar 08, 2008 | Kenmore 63942 Dryer
Dryers Logo
82 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
