Question about RTO Lp Gas Tankless Water Heater By Marey
Whereis serial number located on marey tankless water heater
Portable lpg 5l
2 Suggested Answers
SOURCE: I have a Marey LPG
Ok i intall tankless water heaters and sell them and repair them . The trouble your are hving is more than likely ,the mixing valve on your shower has a ajustment on it to prevent you from burning your self . that is the number one reason in showers when water never get to temp . What it is doing is addng cold water to your shower for you bummer . Take handle off and adjust water temp to your hottest setting . Some times you have to remove the low flow washer in shower head to get the right flow . also every time you start up your hot water it shouldbe set all the way ot other wise withe the battery 2 D models the unit will not sence flow and shut off the unit ,with some units it is a fine balancing act to get them adjusted right. If your buying a tankless water heater always buy a blower type unit that has a computer that runs it . You will be happy . If the Battery operated unit is for a cottage or a smallcabin then your just going to have to fix the pumbing to make it work right many of the safety features of the newer showers are not made to work well with tankless water heaters .
Posted on Apr 05, 2012
HOW DO YOU THE FRONT COVER OFF A 16L WATER HEATER
you remove the knobs by pulling them. then underneath the heater there are 2 screws on each of the back corners. will be inside a little as noy flush with the bottom of the heater. then pull the cover towards you at the bottom until it clears enough to then push up to come out of the top taps.
Sep 22, 2016 | Marey Heater Corp Tankless hot water...
Ignition problem
Sometime the batteries in the drawer fade (yes even new ones). I am asking, is that after the flow initially stops, the Automatic Start will not fire up when there is a demand for hot water (Is this what you meant when you say "The water is turned off" and "Then on again". Check the batteries for being the right way around (I Have installed them 1/2 forward and 1/2 back ward as a set, the one cancelled the other one out....my Bad....Ooops) The battery should be only needed if the power fails, but not sure about this model. Does the Owners manual say anything about no hot water? IF that was tried, you may need to call the heating / cooling techs that are familiar with this unit.
Nov 30, 2014 | Marey Heater Corp Marey Natural Gas 2.0...
Bought a rheem rete 13 off ebay
Question posted under Rheem tankless water heater:
Call Rheem at 800 432 8373
They will need serial number located on label on side of unit.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Usually I recommend that people tear out their tankless water heater and sell it on ebay, and then install tank-type heater from different manufacturer:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
I would be very reluctant to connect used gas appliance without a product manual, and service manual.
http://waterheatertimer.org/images/Exploded-house3.jpg
Mar 19, 2013 | Rheem Tankless Hot Water Heater...
Where can i get a o ring for that litte disc in the water control valve
I assume you have a tankless since you have water control valve.
You posted under Rheem.
Open following link for troubleshoot resources, including contact information for Rheem:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Rheem will ask for model number and serial number that show on information plate usually located on surface of unit.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 12, 2011 | Rheem Water Heaters
I have a Marey LPG tankless heater. The water temperature fluctuates. At my kitchen sink - warm water. In my bathroom shower lukewarm water. At my outdoor shower - nice hot water. How may I fix this...
Apr 16, 2011 | RTO Lp Gas Tankless Water Heater By Marey
Constant water leak from the valve that came in the MAREY water heater
That is the temperature pressure relive valve (TPV) . It is either foiled with some thing or going off because of a pressure or temperature problem. If it is leaking continuously it is foiled and needs cleaning. If I where there I would replace it with new.
Feb 08, 2011 | RTO Lp Gas Tankless Water Heater By Marey
My tankless indoor water heater has an error code C4 76
Error code 76 indicates a communication error with the electronic board and the unit. Call Paloma/Rheem with the serial number and model number of your unit and they will, in most cases, send you a new board with instructions on how to easily replace the board.
Tech Support: 800-432-8373.
Nov 21, 2010 | Rheem Paloma Tankless Water Heaters...
RTO Lp Gas Tankless Water Heater By Marey Logo
82 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
