Question about NetGear N300 Wireless Router
Netgear n300 won't connect to sony Bravia
Sony Bravia TV will not connect to netgear n300 router. The TV sees the router but connection always fails.
  • 35 Answers
SOURCE: Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Posted on Mar 19, 2009
redhaze89
  • 854 Answers
SOURCE: Can Not connect to NetGear MR814 v2 Router with Acer Extensa 4420
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Aug 13, 2009
SOURCE: Can't obtain IP - Net Gear WNR2000 router
Try to open the Router page using "ROUTERLOGIN.COM" in IE and go to WAN Setup option in which u can see Disable SPI Firewall (check the box), also reduce the MTU Size to 1400 or 1390
Posted on Sep 16, 2009
PC Commando
  • 142 Answers
SOURCE: xbox360/netgear WGR614 V9 connection issue
Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
Posted on Sep 19, 2009
anandg27
  • 1272 Answers
SOURCE: i cant connect my netgear router to my sony vaio the
Follow the steps below to reset and reconfigure your router:
RESET:
At the back of the router you will find a small tiny hole (which says restore to factory default settings). Press the button with the help of a paper clip and hold it down for 30 seconds. After 30 seconds, please release the button and power off the router for 5 seconds then power the router back.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 21, 2009
Netgear N300 is slowing down my internet connection
The router limits the data speed to the wireless reception.
802.11 G speed (maximum) is 54Mbps.
Jul 17, 2013 | NetGear N300 Wireless Router
I just got a Canon Pixma MG5370, Im running an XP cp to network thru Netgear N300 then thru DSL, the N300 dangles a Netgear 8 port wired Switch. I cant get the dam printer to connect correctly to print,...
Set a static IP on the Canon printer
e.g.
IP: 192.168.x.x
Subnet mask: 255.255.x.x
Gateway: 192.168.X.1
DHCP should always be enabled on the router for your other devices to work.
Nov 01, 2012 | NetGear N300 Wireless Router
Cannot connect to internet through netgear n300 wireless router
They are pretty straight forward. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Try resetting it by holding the reset in till it cycles through. This will clear all custom setting and try again.
I normally don't suggest firmware upgrades, but try updating.
192.168.0.1 Defual login if you cleared custom is User: admin Password: admin
http://www.downloads.netgear.com/files/DGND3300v2_UM_14Oct10.pdf
Other than that the unit is damaged / defective.
Oct 25, 2012 | NetGear N300 Wireless Router
Router keeps dropping. I have to unplug and replug to connect. this is an n300 - never had problem with previous netgear router
Try going to windows logo
type in search box cmd
when black screen appears type ipconfig /release
When finished type ipconfig /renew
See if that helps
Sep 01, 2012 | NetGear N300 Wireless Router
Netgear n300 will not connect to internet
There should be a little red button that you can push. It is the reset button. Hold it down for around 10 seconds, and try again.
Jul 04, 2012 | NetGear N300 Wireless Router
I have two rj45 points looped with a router and xbox 360 plugged into both but only one will work at a time?
I would figure that you would start with the modem feeding the N300, then connecting the XBOX by cable to the netgear, and then using the laptop wirelessly through the netgear...The modem should feed the Netgear so the Netgear can split the signal...
Jun 09, 2012 | NetGear N300 Wireless Router
Have NetGear N300 wireless router (wnr 2000v2)fed by motorola surfboard modem. N300 Port 3 output feeds OOMA internet phone system, Port 4 output feeds HP Touchsmart desktop pc (windows 7). PC will not...
hi,
go straight from your motorola to each wired computer to see if its a wire.can you can login to the router through your wired computer(touchsmart) in the settings and see if all your wired devices are listed, look at the parental controls, reset the whole router to default if you can, if your DSL. try a different jack in the house, get everything off that line but the motorola. go straight from the service jack outside the house(in the grey box) if you have to
jm
Jul 04, 2017 | NetGear N300 Wireless Router
Can't connect tot wireless service because of windows firewall
to connect wireless service to your netgear, we need to connect your laptop directly to the router hardwired. and by ensuring that we are connected try to open a browser and type this inside the address bar. 192.168.1.1. default username is "admin" default password " password " you would be taken to the netgear page. then on the leftside of the screen click on to wireless settings. there you can configure your wireless settings. and click on to apply settings. then try to connect again.
Aug 31, 2011 | NetGear N300 Wireless Router
NetGear N300 Wireless Router Logo
145 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
