When set at a constant speed it goes slower and faster sporadically.
SOURCE: How do you put the treadmill down?
There is a knob on the support bar behind the treadbelt deck. Give the deck a little push up, then pull the knob out and lower it.
SOURCE: how do I adjust the tracking epic t 40 treadmills
If you mean side to side tracking, there are Allen bolts at the bottom rear of both sides of the treadmill. Turn one slightly one way and the other the slightly other way until it's right.
SOURCE: The tread on the treadmill is beginning to slip
The drive belt between the motor and the front roller may be slipping. All drive belts tend to wear with age and will wear more quickly if not aligned properly. Tightening the drive belt according to the directions in your owner's manual may prevent slippage but we don't recommend it since it is easy to overtighten and this can damage expensive drive system parts- you are much better off replacing the drive belt. Some models are designed with a misaligned drive belt so the treadmill can use the side load of the drive belt to reduce operating tension. These will always wear out quickly. Treating the drive belt with belt dressing, will help the drive belt if slipping and will help prevent cracking and splitting of the drive belt. If slipping of the drive belt persists after following these steps, the drive belt must be replaced. Call Icon Fitness @ 1-800-999-3756 for parts
SOURCE: The speed reading on my epic 55o treadmill quit
Under the motor cover, on the left side mounted on the frame is the speed sensor.
It is a little black "bullet" shaped thing clamped to the frame with a wire wrapping around the frame to the electronic board. It may need to be adjusted. Move it as close to the pulley as possible without making contact. If it still doesn't work, inspect the pulley for the 1/2 inch round magnet. It is mounted on the pulley. If it is missing, it may be attached to the metal frame someplace. Place it back into the holder on the pulley and try the treadmill again.
If you still have no speed reading, the sensor will have to be replaced.
Testimonial: "That worked, thanks!"
