Question about Maytag Neptune MAH5500B Front Load Washer
Water leaks from weap hole in bottom of the plastic housing
Why would water leak from the "weap hole" at the bottom of the plastic housing in the front of my mah5500bww front load maytag neptune? It leaks a lot most all of the fill........ not a little.
  • hornekj Jan 22, 2009
    Thanks for the input....but I dont thinks we are on the same page. The hose you spoke of is ok. It hooks to about a 3/8 nipple and then drains back below. The hole I am refering to is about 3 or 4 inches straight over from that hose and about only 1/8 of inch. It appears to be drilled in the face of the large plastic housing. I have already removed the boot and that hose.
    Novelist:
  • 101 Answers
The Maytag's have always had problems with those front door boots leaking and not draining thus leaving a bad mildew smell. What the problem probably is is that the hose that connects to the weap hole is cracked and needs replacing. I would suggest just replacing the entire boot along with the hose. The boot is a pain to replace though, it might take a tech to get it done for you. Let me know if you have any other questions and let me know if this information was helpful. Good luck.
Posted on Jan 22, 2009
When does the water pump need replacing
A qater pump usually starts leaking from a small hole in it called a weap hole. When you see coolant leaking from the pump its time to teplace it
Sep 27, 2014 | Cars & Trucks
Bad water leak,looks like it's comming from around the belts .water pump?
It sounds like the water pump is leaking from the weap hole.
Double the hode connections, and hoses. If they look good then it most likely need a new wayer pump
Nov 26, 2010 | 1997 Geo Metro
Water coming from pulley system
Hi, if you have water from the pulley area, it may be coolant leaking from the vent hole, in the water pump. This would leak more when cold, than hot. The repair, would be a water pump replacement. This is a fairly easy job, the only possible obstacle, is the fan needs a special holding tool, to dissasemble it. Otherwise, removing the upper radiator shroud, belt, and hoses, there are 4 bolts holding the pump to the engine.It is imparative that the engine block is clean , (to the metal), before the new pump goes on, then a mix of 50/50 dexcool, and distilled water, to refill the cooling system. Good luck...Coop
Sep 30, 2010 | 1999 GMC Suburban
Water pump is leaking
If its leaking from a mount bolt then your gasket went bad.....get a new gasket and some permatex
However if it looks like it is leaking from the pully its self then it is leaking from the weap hole, when this happens it is because the seal arround the berrings has gone bad. You have to get a new water pump
Nov 27, 2009 | 1998 Chevrolet Cavalier
Leaking coolant from around water pump just put in new radiator on monday and no leaks from it or hoses, think is weap hole in bottom of water pump.
If it's the weap hole the pump is going bad. That hole is designed to leak as a "warning" that the pump is going to fail.
Oct 29, 2009 | 1997 GMC Yukon
Leaking coolant from crank seal on 1991 toyota sr5 4x4 pick up. i figure the water pump has a seal gone behind timing cover and no other leaks it over heated today at highway speed .
THE WATER PUMP HAS A WEAP HOLE ON THE BOTTOM OF THE HOUSING THAT INDICATES PUMP FAILURE BY LEAKING WHEN THE PUMP NEEDS REPLACING. IT IS TIME TO REPLACE THE WATER PUMP. IN ADDITION YOU MAY WANT TO REPLACE THE TIMING BELT AS WELL WHEN YOU REMOVE THE TIMING COVER AND CRANKSHAFT PULLEY. I HOPE THIS CLARIFIES ANY QUESTIONS YOU MAY HAVE. THANKS FOR USING FIX-YA AND FOR ANY COMMENTS YOU WISH TO SHARE. PLEASE KEEP ME POSTED. GOOD LUCK
Sep 21, 2009 | 1995 Toyota Camry
John Deere 445 lawn tractor is leaking coolant
This model has a weap hole just under water pump.If it leaks enough it will stain front cover just to the side of crankshaft.Do not buy the rebuild kit,just replace pump.
Apr 18, 2009 | Garden
Water leak at front of washer
You should have a drain at the bottom of the rubber boot inside the washer. There is a possibility the drain hose clamp came loose or the boot has a hole in it. If you take the front of the washer cabinet off, you should be able to see where the water is coming from. Take the two screws out of either side of the door opening, pull on both sides of the front panel at the same time, tilt downward, and the panel should come off.
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
345 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
