Robertshaw 9600: Temperature rises too high, fan doesn't stop.
Temperature rises beyond setting. I usually have to switch to air conditioning/ summer to stop process and cool office. Sometimes (today) fan doesn't stop and temperature is up to 87 degrees. If I get the fan to stop and the temperature cools, I set it at night to 65 degrees with fan on auto. When I get to my office in the morning it may be 80 degrees with the fan non-responsive.
Thanks in advance for any advice.
  • Dale Koehn
    Dale Koehn May 11, 2010
    thanks for your question, I would like a little more info if possible, what kind of t-stat do you have to run the unit ? if its programmable have you checked the programing? you may have a bad stat, if you would get back to us and let us know what kind of stat you have, if its programmable, some here can help you, thanks again, mr.grzz
My ac has worked fine recently, but then today it has started to act weird. The house was at 78 degrees and when the ac turned on it went to 80 degrees. What is the problem?
Posted on Sep 01, 2009
    Problem Solver:
  • 8 Answers
It sounds like the thermostat is wired improperly. One quick was to check is by finding breaker to unit and shutting off power. Go to thermostat and remove from wall take all wires off thermostat besides wire going to R(might be RcandRh) and C(which is common) Tape all bare wires removed with electrical tape. Now go back to the breaker and turn power back on. Nothing should be running at all. Take a voltage meter and measure the voltage from R to W(which is heating). If you read 24V then the thermostat is open and not calling for heat. Now turn the thermostat up so it is calling for heat. You should read 0V from R to W. If this checks out your thermostat is probally fine. You can check the fan the same way by going from R to G. In auto you shoul read 24V from R to G and in th on postion you will read 0V from R to G. If the thermostat checks out then the problem is probably at the furnace or rooftop. Either with the thermostat wiring or the main board acting up
Posted on Jan 22, 2009
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
04 Saturn vue compressor turns off when fan is set to 3 or 4
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing. I exchanged mine and it works like a charm now.
May 31, 2012 | 2002 Saturn VUE
The AC on my 2002 chevy S 10 just suddenly stopped blowing cold air. The freon is full and the compressor is coming on. Any advice would be helpful in this Texas heat. Thanks
If the freon is full and the compressor clutch is working,is the blower working, need more details, if it is, you could have a blocked orifice filter. or a bad high pressure switch located at the rear of the compressor.if the high pressure switch loses voltage or goes out, your cool air will come to a dead halt. check the high pressure switch for voltage. good luck!
Aug 08, 2011 | 2002 Chevrolet TrailBlazer
MY FAN MAKES ALOT OF NOISE JUST THE BIG FAN WORKS THE SMALL ONE DONT WORK AT ALL HOW CAN I FIX THE PROBLEM...
Fans are usually controlled by a thermo switch located in the radiator. The switch senses water temperature and when it goes beyond the designated level, it triggers the 'small' or 'low' fan. If the water temperature still rises, it then triggers the 'big' or 'hi' fan but via the 'small' fan through the use of a relay. So I suspect the thermo switch is faulty. What car / truck is it by the way?
Apr 30, 2011 | Volkswagen Jetta Cars & Trucks
I have a RobertShaw 9600 and would like to set
go to there website and print the set up instructions, this should give you stsep by step set up.
Oct 27, 2009 | Heating & Cooling
No display on Robertshaw 9600; unit seems dead/furnace works
have you checked to make sure you have a fresh battery in it
Jul 25, 2009 | Shaw Robert RS-9420 Thermostat
Robertshaw 9420 thermostat engages inside fan in OFF position
check with the company u brought it from and check if you have not put the correct conector to the right temals on the back of the switch.
Jun 09, 2009 | Heating & Cooling
2 zone sytem main floor cooler than what i set it to
Warm air rises and if the upstairs thermostat is on it will onerride to lower the temp upstairs. To have the dowstairs thermostat govern, the up stairs must be off . The whole house will balance to the controlling thermostat.
Jun 02, 2009 | Honeywell Programmable Thermostat Heater
Thermostat problems
Have you confirmed that the thermostat is programmed correctly?
Did the thermostat ever control the temperature of the house properly?
When you indicate "kick", are you talking about flipping the Auto-On switch back and forth? The Auto-On switch only controls the fan, and no heating or cooling (Auto - fan runs on call for heat or cool, On- fan runs all the time.).
If "kick" means making the heating work, and if you have the same problem for making the cooling work, chances are good you have bad thermostat.
If the problem only occurs with the heating, and cooling works fine, then the problem could be in the controller board of the furnace, assuming you have a more recent (1990's or newer) furnace.
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
342 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
