Question about GE DBXR463EBWW Electric Dryer
Dryer heats with smaller loads
I have a GE dryer that is about 7 years old. While trying to trouble shoot what is exactly wrong I have noticed the following things
1) when disconnected from the vent dryer will heat(does not when connected)
2) The larger the load the less dryer that occurs i.e if I dry a small load it will eventually dry after a few cycles but larger loads never seem to dry
3) there seems to be limited exaust from the vent in the dryer, this might be due to the limited heat in the dryer itself
The fact that it does heat leads to believe the element is fine
thanks for the help
  • noonej21 Jan 20, 2009
    So even if the element seems to be heating up there could still be an issue with it? My first thoughts were to check the venting, from the dryer to my house foundation is fine(I need to check inside the dryer itself) I cannot check the outside venting since it runs under a deck that it surrounded by snow. But the fact that it still did no run properly even when unhooked from the vent led me to believe a sensor or fuse was blown. Thanks for the help
    Problem Solver:
  • 20 Answers
1. unplug your machine and rach as far in the exhaust part of the dryer to see if there is an obstrucxtion
2.Take out the lint filter and make sure there are no gaping holes in the screen
3. Check the exhaust house leaving the machine or blockage, this hose should not run more than ten feet for optimal drying time.
4. its your heating element
Posted on Jan 19, 2009
Samsung dryer. It starts, but it doesn't get hot?
Samsung Dryer Diagnostic Repair & Diagnostic - Not ...
? 19:33
https://www.youtube.com/watch?v=a-8UFyRXBDg
Feb 7, 2014 - Uploaded by ApplianceVideo.com
Troubleshoot your own Samsung Electric Dryer that has some of the ... It powers on but when I get start nothing happens... drum spins but not ...
How To Fix A Clothes Dryer That Is Not Heating Or Drying ...
removeandreplace.com/2013/.../fix-clothes-dryer-heating-drying-clothin...
Sep 21, 2013 - At times your dryer can overheat and this can cause the motor that turns the ... Clothes Dryer Will Not Stay On After Pushing Start Button My dryer will run if I ... I have tried the trouble shooting tips for a dryer that doesn't dry but to no avail. ..... I have a 3 year old electric Samsung dryer and it stopped heating.
[FIXED] Samsung dryer runs, no lint clogs, good airflow, but no ...
forum.partsdr.com > Forum > Appliance Repair Help > Dryer Repair
Mar 12, 2013 - 16 posts - ‎4 authors
I want to check the third harness it but it doesn't look to slide out too easy once I remove the one phillips screw. ... Dryer gets nice and hot now!
Jan 19, 2016 | Samsung Dryers
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Ge front load dryer not heating three years old model # dbvh520ej2ww
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 11, 2011 | Dryers
Dryer is about 5 years old. Has begun to squeak loudly when clothes begin to spin
Are you comfortable taking the dyer apart? There are just a few simple screws to remove. It sounds like a bad blower wheel. If you follow the link you should be able to trouble shoot the issue.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info
Mar 01, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
I have a GE DDE5100 electric dryer. On the permanent press mode there is no heat; however, on the regular mode there is heat. Looking to attempt to trouble shoot and repair. Thanks for your help.
heatman101
Jan 04, 2011 | Dryers
Sears Kenmore super capacity plus dryer won't heat up 90 series, about 7 years old. It heats up for the first few minutes and then gets cold
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
HOW TO FIX A NO HEAT ON A GE ELECTRIC DRYER OVER 10 YEAR OLD
Either one of 2 ways to get to the thermostat on a GE dryer.....
depending on your model, you will have an access point on the back of the dryer to get to the heating element which has attached to it, the thermostat.
If there isn't an access point on the rear of the unit, open the front door of the dryer and remove the 2 screws in the top of the door opening. Using a small prybar, slightly apply pressure prying up the lid. On the inside of the face of the dryer in the corners will be 2 more screws, remove those and pull the face of the dryer outwards to you to about a 45 degree angle. From there, you will be able to lift off the face. Be cautious to unplug the wires for the door switch before pulling the face all the way out. There isn't much to a 10 yr old dryer, just take your time, study the parts and put it back just as you took it apart. For the replacement thermostat or heating element look at
www.marcone.com
www.partstoday.com
Good luck and let me know if there is any more trouble I can help with.
Mar 17, 2008 | GE DCSR483EA Electric Dryer
GE Dryer
Sounds like an intermittant break in the heat element. Could also be an irratic control thermostat or bad connection somewhere between the line and the heater. Simple to isolate with a tester.
Jan 04, 2008 | GE DCSR483EA Electric Dryer
GE dryer
IF YOU HAVE HEAT & ITEMS ARE STILL WET/DAMP.YOUR PROBLEM IS WITH THE VENTING.CHECK YOUR OUT SIDE WALL CAP,VENT HOSE,IF THEY ARE CLEAR,YOU WILL HAVE TO TAKE THE FRONT OFF & CLEAN OUT THE BLOWER HOUSING & LINT FILTER AREA.
Nov 20, 2007 | GE DBVH512EFWW Dryer
GE DBXR463EBWW Electric Dryer Logo
95 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
