Question about Dell Computers & Internet
Dell studio low memory
Computer says low memory and shuts down running programs. I am usually only using my firefox browswer and it still shuts it down and i have to restart my computer.
  • Dell Master
  • 32,281 Answers
Low memory problems could be low virtual (hard disk) memory.
Hard disk maintenance will free up hard disk memory space.
Hard disk maintenance should be carried once a month to make your computer run efficiently.
This removes redundant and temporary files, recovers disk space and speed up hard disk access.
Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too.
Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment.
When this is completed repeat these steps for the D Drive if you have a D drive.
Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
Posted on Jan 04, 2013
SOURCE: problem with computer shut down when using Maplestory & other P2P games
try to uninstall all security softwares and just install the most reliable one. That should fix your problem.
Hope this helps.
Thanks,
Karlox™
Posted on Jun 12, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Dell Inspiron 8600 - overheating and shutting down
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
Posted on Jul 22, 2008
ginko
  • 19396 Answers
SOURCE: low memory slow running video/audio programs host process stop working
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
Posted on May 21, 2009
  • 3940 Answers
SOURCE: Screen is black after sleep/hib, Dell studio XPS, Vista.
Hibernate problems are generally associated with the Video Driver. Suggestions:
  1. Update the BIOS to the current release. Here is the latest for the 1645. http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=STUDIOXPS1645&os=WV64&osl=en&catid=&impid=
  2. Update the video driver.
Posted on Dec 21, 2009
SOURCE: My girlfriend got a dell inspirion mini 10 for
Thats just your computer ending the process of skype.
As for the pc shutting down automaticly it can be that its oveheating!!
On my Dell Inspiron 2200 I get the Blue Screen every 2 hours and I dont mind.
Might be bad memory
Posted on Dec 30, 2009
Qt 6100
see this instruction and proceed according. God bless you
To partially clear computer RAM memory, close some programs that are currently running. In Windows, right-click on any program in the task bar and choose the "Close" option. That will free up the memory that was used by the program. Even if you close every program running on the task bar, a big chunk of memory is taken up by the operating system. The RAM used by the operating system cannot be cleared without shutting down the system.
  • 2 To clear computer RAM memory totally, you have to shut down the system. In Windows, click on the Start Menu and click the "Shut Down" option. Unix and Linux have similar options. When this process is complete, all RAM will be cleared.
  • Sponsored Links
  • 3
    If you are somewhat impatient, turn off the computer by pressing the power button on the computer. This is slightly quicker than the previous step.
  • 4
    If you are very impatient, unplug the power cord of the computer. If it is a laptop, disconnect the battery as well. The computer's RAM memory will be cleared immediately upon the power source being disconnected. This method of shutting down the computer usually causes corruption or some other problem when the operating system is booted up again.
  • Read more: http://www.ehow.com/how_5054182_clear-computer-ram-memory.html#ixzz2ZPe6cBFn
    Jul 18, 2013 | Computers & Internet
    CAN I CHANGE MY MOTHERBOARD 2 INCREASE THE PERFORMANCE OF MY DELL STUDIO 1450
    Very hard and expensive to replace a motherBoard on a laptop.
    If you have performance problem try to clean the computer from all malware, using malwarebyteantimalware . the ferr version is excellent.
    After disable all program that open when you start your computer. CCleaner has the option to do this and it will also delete unnessessary files ...
    If you still have preformance problem you could change the memory chip in your laptop for a bigger one ... but usually the clean-up is enough
    May 08, 2013 | Dell Studio 1537 Notebook
    Memory problems
    How to prevent low memory problems Running fewer programs at one time can help prevent low memory problems and information loss. It's a good idea to observe which programs show signs of low memory conditions and try not to run them at the same time.
    However, it's not always convenient or practical to run a limited number of programs. Signs of low memory can indicate that the computer needs more RAM to support the programs you use. Here are the recommended ways to solve or prevent low memory problems:
    • Increase the paging file (virtual memory) sizeWindows automatically attempts to increase the paging file size the first time your computer becomes low on memory, but you can also manually increase it up to a maximum size that is determined by the amount of RAM installed. Although increasing the paging file size can help prevent low memory problems, it can also make your programs run more slowly. Because your computer reads information from RAM much faster than from a hard disk (where the paging file is), making too much virtual memory available to programs will slow them down.
      For more information, see Change the size of virtual memory.
    • Install more RAM
      If you see signs of low memory, or if Windows warns you about a low memory problem, check the information that came with your computer or contact the computer manufacturer to determine which type of RAM is compatible with your computer, and then install more RAM. To install RAM, check the information provided by the manufacturer.
      For more information, see Find out how much RAM your computer has.
    • Determine if a program overuses memory
      If the computer becomes low on memory whenever you run certain programs, one or more of those programs might have a memory leak. To stop a memory leak, you need to close the program. To repair a memory leak, you need to check for updates for the program or contact the publisher of the software.
      To determine which program is using the most memory, follow these steps:
      1. Open Task Manager by right-clicking the taskbar, and then clicking Start Task Manager.
      2. Click the Processes tab.
      3. To sort programs by memory usage, click Memory (Private Working Set).
      You can also check for program errors and troubleshooting information using Event Viewer.
      1. Open Event Viewer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, clickingAdministrative Tools, and then double-clicking Event Viewer. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
      2. In the left pane, click Applications and Services Logs to view error events. To see a description of the problem, double-click the event. To see if troubleshooting information is available, look for a link to online Help.
    Mar 08, 2013 | Dell VOSTRO 3350
    How to solve memory problems in dell studio 15 its giving a message that u may loose ur data or ur computer might stop working
    Hi.
    Maybe you not have enough ram because you use programs who need more memory.Try to update your ram to double up at least 1 GB.
    Mar 09, 2010 | Dell Studio 15 Laptop
    My dell studio 1555 is slow in getting started. any solutions?it takes long time to open the programs.
    Try this: http://www.revouninstaller.com/revo_uninstaller_free_download.html
    It will recommend software you can remove to speed your PC up.
    Nov 27, 2009 | Dell Studio 15 Laptop
    I have a Dell Pentium 4 with Windows XP home that is slowing down and at times locking up making me have to restart. Occasionally I get a flag from Microsoft Security informing me that they are adding to...
    your problem is not with your hardrive i had xp rnning perfectly on a pc with a15gb and a 3gb in it
    bassically about 18gb
    and memory he probably means ram
    bassically you have too many apps running at once and not enough ram so it wants to use your hdd to emulate it and thats why its low
    yes you can get rid of intenret explorer go to control pannel
    add or remove programs
    windows comonents and select internet explorer
    good luck
    Sep 21, 2009 | Computers & Internet
    Do I Need MORE RAM?
    Hey bro, a gross consumption of system resources s a good sign of... sorry to be the one to tell you, but a virus. A good free virus removal/detector is avg ( http://free.avg.com/ ). If this isn't the problem, you might want to shut down extra junk. You can delete stuff from your Programs folder, or you can do a temp thin. Under run on the start menu, type msconfig. From here, you can shut down any programs that you don't need. Just make sure to restart when you're done.
    Jun 17, 2009 | Dell Inspiron 1521 Notebook
    Dell 2400 dimension desktop
    When you said "I think its a memory problem" your right, you need more of it. Try adding more RAM. It's really cheap now a days, especially for the 2400. Memory is available everywhere. While this is not an endorsement of their site, Computer Memory Outlet.com has about the cheapest RAM available and they are reputable and reliable and orders usually ship next day. I personally get all my memory from them.
    anaanymous
    p.s. They have an on site utility that will scan your computer and tell you the exact RAM you need and the maximum RAM you can add
    Oct 12, 2008 | Dell Dimension 2400 PC Desktop
    Computers & Internet Logo
    mukhtar21 shaikh
    mukhtar21 shaikh
