How to replace the fuse in the lasko 5620 heater
4 Suggested Answers
SOURCE: lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Posted on Nov 10, 2008
farfield
  • 462 Answers
SOURCE: Cannot get the heating element to turn off properly on Lasko 5620
From whatI have seen on base board heaters if I recall correctly, the thermostat may be sepperate. Usually thermostats on these have a round knob. 1 line goes to this and the other side of the thermostat goes to 1 end of th element and the othe line attaches to the other side of the element. Its possible you have the element wired in directky if it came without a thermostat and without instructions it may till be connected directly. You should have an L1 and L2 connection and hope there is a wire diagram on the cover.
THE reason these basebord heaters used to come without a thermostat is because they are (OR WERE)set up to add on additional heaters comming right on down the wall. At the last one you could tie in and get a correct rated thermostat installed in the center of the series.
Return to LOWES and ask them to remove the instructions and copy them for you from another like model. Or have them contact the manufacturer and request they fax a copy of instructions with a diagram. Also ask if the heater comes with a thermostat. It may stoill be sepperate in another kit.
Posted on Mar 04, 2009
  • 4 Answers
SOURCE: yellow caution light
I also have the model 5620. with the yellow caution light on. After taking the unit completely apart I found 2 thermal fuses on the bottom of the unit(appox. size of a nickel). They are located under 'U" shaped brackets which are below the medal heating element. The thermal fuses do not reset. you could test them with a drip or two of souder or wire on the top - if you ran the heater this way it would be a safety problem as the fuse would be overridden. I am throwning mine away.
Posted on Jan 11, 2011
Cant get the heat to go past 71
Check your thermostat. Maybe it's cutting off ahead of the set temperature. May need recalibration or replacement.
Nov 12, 2012 | Lasko 5620 Electric Baseboard Heater
Caution light
when did this started happening?
Mar 16, 2008 | Heating & Cooling
Orange light came on
The orange light is just an indicator light to show you that the heater is working...there is nothing wrong and nothing to worry about...
heatman101
Jan 04, 2011 | Lasko 5620 Electric Baseboard Heater
Heater thermostat kiks off aftre about 5 min.
First check the wiring to make sure that there are no loose connections... also check the thermostat to make sure that the heat is not affesting it directly and that the sensing part of the thermostat is away from the elemnt enough to sense the ait temperature and not the element heat....
If all of that checks out then try to change the t-stat... it is bad...
heatman101
Dec 15, 2010 | Lasko 5620 Electric Baseboard Heater
Our Lasko 5620 has a digital control, but we can't set the temperature. It says at 76 degrees, no matter what we do. Hitting the control buttons does not work.
Based from your comments, it seems that you have a
defective digital control. Have a check up for this item.
It may need to be replaced. Hope this will help you.
Jan 10, 2010 | Lasko 5610 Baseboard Heater
Need manuall for model 5620 electric baseboard heater
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
Jan 04, 2010 | Lasko Under Desk Space-Saving Area Heater...
Mar 04, 2009 | Lasko 5610 Baseboard Heater
Absolutely no power to my Lasko 5540 heater
There is a thermal fuse in line with the power chord. Open your heater housing up and trace the power cord. It is located inside a white teflon sleeve. Locate the fuse and either replace it with the same value. Appliance repair shops will have them in stock. If you want heat right away, cut out the fuse and jumper the 2 wires together. Instant heat.
Nov 21, 2008 | Lasko 5540 Ceramic Compact Heater
Yellow caution light
Lasko heater model 5620
Feb 12, 2008 | Heating & Cooling
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
