Question about JBL PSW-D110 Speaker
Jbl subwoofer keeps blowing the fuse
Replace the fuse and after I plug the subwoofer in the wall it goes off again
SOURCE: fuse blows
Presuming you're referring to the circuit breaker in your house, it's probably because you have too many items on that circuit. Your best bet would be to find another power outlet that is on a different circuit, and plug some things in over there.
Posted on Jun 19, 2008
djicenova
  • 319 Answers
SOURCE: dead JBL EON 15P-1
bad power board. short on board
Posted on Feb 27, 2009
  • 45 Answers
SOURCE: Fuses keep blowing
This particular product has a lot of comments posted on it and I've answered a few of them now so I'm beginning to think you may want to look into weather or not the manufacturer has received any complaints or this is just a freak occurrence. Keep in mind not all commments are the same so this may just be nothing. Either way I can tell you this much, if fuses keep blowing quickly, over and over again-You have a direct short somewhere and will most likely be in need of professional assistance of some sort with the possiblilty of having to replace it. I'm sorry it's not an easier fix but it may not be too expensive.
-Dynami
Posted on Mar 29, 2009
SOURCE: No Sound from my JBL SCS135 Subwoofer
no sound
Posted on Aug 26, 2009
SOURCE: JBL PSW-D112 Speaker fuse blow immediately after replaced
The Problem in this unit is the Amplifier module S64AMI,which is surrended in a black heatsink, filled with epoxy, not serviceable, the bad news is that JBL discontinued this module and is really hard to find, sorry....
Posted on Nov 21, 2009
JBL subwoofer not giving sounds even it is correctly connected
If this is a powered sub, than it will have it's own power supply and small mono amp, both of which can fail. Could be a fuse, but if the fuse blows again you will have a short on the main amp board.
Nov 20, 2015 | JBL Audio Players & Recorders
Jbl subwoofer fuse
there is a short in the amp that would need to be fixed before the unit will power on
Dec 12, 2013 | Audio Players & Recorders
My jbl pb 10 has a noise and it burn the fuse... changing the fuse it burn the fuse again..so it might have som other defective part that is causin the noise and the fuse burning... any sugestion?
It blows the fuse because a semiconductor device has developed a short (in otherwords acting like it was just a piece of wire). Because of the noise I would suspect the main amp device is the cause. It will be most likely on a heatsink.
Feb 06, 2010 | JBL PB10 Subwoofer
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Fuses keep blowing
-Dynami
Mar 22, 2009 | JBL PB12 Subwoofer
Psw1200 paradigm sub woofer
If your fuse keeps on blowing after you cg=hanging,that meens that there is a shortage.check it first using the multimeter.good luck.
Dec 28, 2008 | JBL PSW1200 Speaker
Blown fuse??
there is an underlying cause for the fuse to blow. if something shorts out you would rather a 40 cent peice goes then the unit causing a fire. disassembly is require... look for obvious burnt parts first.
Robert
Sep 01, 2008 | MTX SW2 Subwoofer
Fuse blows
Jun 17, 2008 | JBL PB10 Subwoofer
Blows fuses
I found a post where someone replaced several capacitors with ones he described as titanium and a higher voltage like 100 v rating rather than 50 as oem. He states no more problems. I found this site while searching again. I also found a free download pdf repair manual from JBL - site defined as Harmon, and they show revised parts replacements for these caps - 100 volt. I just bought a used one and not hooked up as yet, but I plan to use slow blow fuses and possibly a little higher rating - not much though, and I believe there is a ceramic type - color solid white - that may withstand the apparant surge. Theres also a recent post somewhere for sale of the amplifer board... 64smi or something like that. Hope this helps. Ken
Jan 08, 2007 | JBL PSW-D112 Speaker
JBL PSW-D110 Speaker Logo
53 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
