Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge model emo3000hss05 microwave shut down and will not work at all
Was working and went to use it again and it has no power to anything
vitg55
  • 73 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Posted on Dec 15, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE spacemaker Microwave-Model # JVM1441WD003 no heat -clock ok
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Feb 15, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: microwave power shut off and stopped working
You can test safety thermostats with an ohmmeter. There should be a short circuit between the device's two terminals if it's closed. (This doesn't necessarily mean the device is good, though. It might be opening at too low a temperature when the oven is operating.) A high resistance or an open circuit means the thermostat has opened and needs to be replaced. An appliance parts store should have suitable replacements, or you can order from a number of online vendors. I usually start at the Sears parts site. They have part information for many models, and usually pretty fair prices for parts. But once you have the part number you need, a Google search will let you shop around.
It does sound like your oven shut down because of a thermostat. One is normally mounted on the magnetron tube that supplies the microwaves, and another is on the cooking cavity. I've had to replace these many times. If the main power fuse blows the oven will not come back on until it's replaced. But you might also have bad solder connections causing the trouble as well. I've seen solder joints on the control board and power filter board cause dead ovens.
If you're not absolutely sure of what you're doing working on a microwave, you might want to let a professional check it over and make an estimate. There are potentially lethal voltages present, and microwave leakage may be a concern as well.
Posted on May 28, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Touch sreen won't work
I would suspect it either needs a hard reset (unplugging it for a few minutes, then trying again) or the membrane keypad is failing.
Instead of JMV1540BMC01, it would probably be one of these models:
JVM1540DM1BB
JVM1540DM1CC
JVM1540DM1WW
JVM1540DM2BB
JVM1540DM2CC
JVM1540DM2WW
JVM1540DN1BB
JVM1540DN1CC
JVM1540DN1WW
JVM1540DN2BB
JVM1540DN2CC
JVM1540DN2WW
JVM1540LM1CS
JVM1540LM2CS
JVM1540LN1CS
JVM1540LN2CS
JVM1540SM1SS
JVM1540SM2SS
JVM1540SN1SS
JVM1540SN2SS
Since FixYa is not currently notifying us Experts when Clarification Requests are answered, feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 11, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
Posted on May 30, 2010
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge model JES1142SJ06 just cut out. No power. Outlet works. it was working and then shut down
Open garbage can lid, and dispose of GE microwave unit. Then buy a replacement.
Jan 03, 2011 | GE Microwave Ovens
Turntable and cooking power not working, everything else does.
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
Oct 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shut off
try to checked the fuse if its blown.and replace a new one,check also the power cord.
Jul 05, 2009 | General Electric Microwave Oven
No Power
It sounds like the fuse blew inside the unit. It can be replaced, but you need to find out what caused it. There are also thermal switches that will turn off the unit if it overheats. They are called "snap discs" because they have only one setting and will shut the unit down to protect it.
If you aren't familiar with this kind of work, do not attempt repairs. Take it to an appliance shop. It could be anything and a competent appliance shop will tell you if it's worth fixing.
Mar 22, 2009 | GE Microwave Ovens
I have a GE Eterna Spacemaker Model Number EMO3000HSS05
Reduced power was selected, perhaps inadvertently
May 07, 2017 | GE EMO3000 Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave shuts off after a few mins. of use
There seems to be a rash of these units failing in this way due to bad magnetrons. The magnetrons normally have a warranty that runs for a few years. In some models, they have a whole kit they replace, consisting of a new magnetron, stirrer, and high-voltage rectifier diode. I would call GE Customer Relations with your model and serial numbers to see if yours is affected. They're at 1-800-386-1215 (8-6 ET). I would also suggest you ask them for a referral to a GE-authorized servide center in your area. Good luck. I appreciate your thoughtful rating of this answer.
Jan 28, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
