Question about Eureka Capture Upright Vacuum Vacuum
I have lost the directions to replace the belt. Can you e-mail me the directions?
  • minni2 Jan 22, 2009
    how to replace the balt eureka boss
  • 328 Answers
If there are no screws on the bottom part/sole plate where the roller brush is, then check the top of the hood - there should be three screws, two at the front on the raised section of the floor brush top and one below the hose if it sits to the left hand side of the machine at the bottom. Undoing them and possibly taking off the rotary dial height control should give you access to the drive belt. Be careful with the seats of the roller brush (what the brush sits in) as these are notorious for falling out and are poorly directioned as to what position they should be in.
Posted on Jan 23, 2009
Kenmore vacuum cleaner model no. 116. 5861279 belt replace
Do you need the belt or the directions for changing the belt? Sears Parts Direct has the manual for the 116.58612790 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/user-manuals/manual-downloads/Model-11658612790/0582/0640500?modelNumber=11658612790&diagramPageId=&documentId= . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0802691.pdf . See pages 14-15 of the manual.
To replace the belt, you need to remove the light cover and then the light bulb. Press in the sides of the cover and lift to remove it. the bulb needs to be pushed in and then turned couter-clockwise. Remove the cover screws. Then flip over the Power Mate and use the flat blade screwdriver to release both tabs. Turn the Power Mate back to right side up and press on the handle quick release pedal and lower the swivel. Tilt the cover forward until it snaps free. Carefully, use your screwdriver to pop the brush supports free on both sides to remove the brush. Slide off the old belt. (If needed, slide off the brush supports and washers. Clean the brush before reassembling the unit. Then replace the brush supports and washers.) Push the belt on motor drive and then onto the brush sprocket. Push the brush supports back into place on the base. (Make sure that this isn't assembled upside down.) Then line up the front of the cover with the base and tilt the cover back into place. Press firmly until you hear both sides click into place. Replace the cover screws, light bulb and bulb cover.
The belt is available here: http://www.searspartsdirect.com/Kenmore-Vacuum-Parts/742024/0020/116/Model-11658612790/0582/0640500.html . This is part number 5285; it's the direct replacement for the original 742024 belt.
I hope this helps.
Jun 16, 2016 | Kenmore Vacuums
NEED ASSISTANCE ON INSTALLING BELT FOR MODEL 8625
HI There,
Here's a link that will walk you through step by step on how to replace the belt on your Riccar 8625 upright. This is an almost identical model, and the belt change is identical to yours.
If you have any questions please feel free to add a comment on the repair, and I"ll be happy to follow up and answer any of your questions.
Please rate my repair or send me feedback if this helped you,
http://www.fixya.com/support/t4184186-replace_belt_riccar
Thanks,
Apr 20, 2010 | Riccar 8650/8625 s Vacuum
ROLER GOT JAMED (LOST MANUAL ) NEAD ADVISE FOR
Make sure it didn't snap the belt. If it did you can get a replacement here:
Dyson DC17 Replacement Belt
Dec 05, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
My hoover upright has no suction, the brushes move but it doesn't pick anything up at all
Hi there...
I had the same problem. Checked for obstructions, cleaned the filters, etc.
 I took out the rubber belt and noticed that it was much more stretched than the newer black belt.   I replaced it, and it made a 100 percent improvement on the suction.
Your vaccuum should have come with a postcard that allows you to mail in belts for new ones. You'll get two new ones in the mail, and they are free for life.  Just keep mailing in the old broken or stretched out ones.
Hope that works!
Mar 17, 2009 | Hoover U5753-900 WindTunnel Bagless...
I need to replace the belt on my vaccum. I lost my manual.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698951
Generic problem for all Vacuums
Posted by 4eversofia on Jun 23, 2008
I need to replace the belt on my vacuum. I lost my manual.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In order to change your belt I would need to know the brand name and the model # in order to give you the correct information to change your belt, so a little bit more information needed as to what you have and then I can direct you in the belt change. Normally there are screws in the bottom of the vacuum and once you remove the screws or clips you can either change it from the bottom or the top cover will lift off and then you can get @ the belt from the top.The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Eureka Capture Upright Vacuum Vacuum Logo
169 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
Roger Potts
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
