Question about Maytag Neptune MAH5500B Front Load Washer
Water leak at front of washer
While the washer is running water leaks from a small "weap hole" at bottom of the plastic tub around the stainless drum. What is this hole for and what might I need to fix this leak?
  • 4 Answers
You should have a drain at the bottom of the rubber boot inside the washer. There is a possibility the drain hose clamp came loose or the boot has a hole in it. If you take the front of the washer cabinet off, you should be able to see where the water is coming from. Take the two screws out of either side of the door opening, pull on both sides of the front panel at the same time, tilt downward, and the panel should come off.
Posted on Jan 25, 2009
Washer leaks but onlyu during drying cycle
the main drama i have with these lg washer/dryers is the drying vent blocks up with lint which causes excess heat build up around the heater and it often results in a small hole melting through the front tub under the heater vent where it joins to the plastic tub, it also results in water leaking out the melted hole when it dries but not during the wash as the hole is at the top of the tub, parts are relatively cheap for what they are but its a massive job to replace the front tub.
Feb 04, 2017 | LG WM3987HW Front Load Washer / Dryer
Burnt smell bits of plastic found inside
A WM1814CW does not have a built-in water heater, so I think your
load may have gotten trapped between the spinning tub and plastic
front tub cover..Roll back the gray gasket to expose and check the
plastic ring for signs of 'friction' burn..As long as the splinters are
trimmed away and doesn't leak water you should be OK..Watch your
loads..Don't Overload!
Aug 18, 2014 | LG WM1814CW Front Load Washer
Amana washer model LW6501W2 leaks in front during fill up
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 01, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Water leaks from weap hole in bottom of the plastic housing
The Maytag's have always had problems with those front door boots leaking and not draining thus leaving a bad mildew smell. What the problem probably is is that the hose that connects to the weap hole is cracked and needs replacing. I would suggest just replacing the entire boot along with the hose. The boot is a pain to replace though, it might take a tech to get it done for you. Let me know if you have any other questions and let me know if this information was helpful. Good luck.
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leaks from bottom
check for cracks and corrosion on the outer tub.thats where the water must be leaking from.good luck.
Dec 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Leaking washer
remove 2 screws bottom front panel pull panel down should drop and can be pulled out of way ckd area around pump also around center shaft where it goes through bottom of tub lest likely hole in tub make sure small hose back left is attached to small connector on side of tub
Jul 10, 2008 | Washing Machines
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Water leaking from bottom of door during wash cycle
this will more likely be your door seal open the door pull your seal so u can see inside and feel around as u look u will more than likely find a hole the water looks like it comes from somewhere else but it will be from the hole in the door seal seen this with hundreds of washers m8
Aug 26, 2007 | Kenmore 43142 Front Load Washer
Water in Outer Tub
My washer does this too and I called Maytag and was told it was normal. I don't like that answer, though.
Mar 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
206 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
