Photography Logo
Posted on Jan 19, 2009
I have a small loggage lock (not on the suitcase) and accidentally reprogrammed it, so now i don't know combo. How do I reset?
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Jan 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1516
Points
5
Go to the company's web site and check their support page.
My delsey combo lock won't lock?
If your Delsey combo lock won't lock, there are a few things you can try to troubleshoot the issue:
  1. Check the battery: Make sure the battery in the lock is not dead. If the battery is low, replace it with a new one.
  2. Check the lock's alignment: Make sure that the lock is properly aligned with the suitcase zipper. Sometimes the lock may be slightly off-center, which can prevent it from locking properly.
  3. Check the lock's mechanism: Make sure that the lock's mechanism is not jammed or damaged. If it is, it may need to be repaired or replaced.
  4. Check the lock's code: Make sure you have entered the correct code for the lock. If you have forgotten the code, you may need to reset the lock or contact the manufacturer for assistance.
  5. Clean the lock: Sometimes dirt and debris can accumulate in the lock mechanism, preventing it from functioning properly. Clean the lock with a soft cloth and mild soap.
  6. Check the suitcase: Make sure the suitcase is not damaged in any way that can prevent the lock from closing properly.
If none of these solutions work, it may be best to contact Delsey customer service for further assistance. They may be able to provide additional troubleshooting steps or may suggest to get the lock serviced.
How do you reset a lock on a hot tuna case please
Picture the scene, you've just arrived at your hotel in an unfamiliar city after a long flight. You put your suitcase on the bed and slowly turn the numbered wheels of the three-digit combination lock. You press the button to get access to your case but nothing happens. The metal zipper tags remain firmly trapped in the lock's clasp...
A locked suitcase with TSA approved combination lock
Getting locked out of your luggage is something that happens to even the most seasoned travellers at some time or another. Luckily the ubiquitous, TSA approved, 3-digit combination locks used by brands such as Samsonite, Eastpack, Antler and American Tourister are easy to open without damaging either the lock or the case and without any special tools.
By following the steps described below, you will be able to quickly open the lock and re-program the code to a new 3 digit combination which is easier to remember.
A 3-digit TSA007 combination suitcase lock
How to Unlock Your Suitcase When You Forgot the Combination If you look closely at the lock from above, you will see that to one side of the 3 numbered thumb-wheels there is a small disk (see photos below).
I have found that the best way to see the disks is by using your mobile phone's camera.
Select the video camera and shine the flash down into the lock then zoom-in to see the disks more clearly.
Starting with the first thumb-wheel of the lock, turn the wheel one click at a time until you see a notch in the disk as shown in the photos.
Once you have lined up the notch of the first wheel you then repeat the process for the second and third digit until the notches of all three wheels are lined up (see the photo of the blue suitcase).
Once all three notches are lined up, turn the suitcase so you can see the numbers.
Note, this is NOT the combination code.
The notch is not visible on either disk
Write down the numbers on the first line of a blank sheet of paper.
On the next line add 1 to each digit.
Repeat this 8 more times until you have a list of 10 3-digit numbers as shown in the photo below.
Try the codes one at a time until you find the one which opens the suitcase.
Once the case is open you can change the combination for one which is easier to remember.
With practice, the entire procedure takes less than 2 minutes.
Video: How to Quickly Open Your Suitcase Lock When You Forgot the Code
When writing this article I used 2 different suitcases, both of which are fitted with TSA approved Travel Sentry combination locks. The locks are slightly different models but the procedure is identical.
I made the video using the older, blue, suitcase because the notches in the green plastic discs are easier to see than the notches in the black disks of the red suitcase.
The code which opened the red suitcase was 2 clicks away from the position with the disks lined up. The code which opened the blue case was 8 clicks away.
If none of the codes which you have written down work you should check that you lined the notches up correctly. As can be seen in the video, there are normally two positions where the notches are visible. Make sure that all 3 notches are lined up in the same position. You can see that in the video I lined up the disks at the right-hand position.
The notch on the left disk is now visible
How do Combination Locks Work?
The 3-digit combination locks used on suitcases are designed so that you can change the combination to a unique code which only you know.
To do this, you have to first set the lock to the current combination. You then press a small button (normally using a ballpoint pen) which frees the numbered thumb-wheels from the locking mechanism (currently in the open position).
You can then turn the 3 numbered thumb wheels independently to a new combination before pushing the larger button (the one which is used to open the lock). This re-connects the numbered thumb-wheels to the locking mechanism, activating the new code.
The method described above relies on the fact that part of the locking mechanism itself is visible (the notched disks next to the thumb-wheels). This makes the number shown on the knurled thumb-wheel pretty much irrelevant. Once the disks are aligned you simply need to rotate them around until the lock opens.
The notches on all three disks are lined up
What Are TSA Approved Locks?
The TSA (Transportation Security Administration) is a US federal government agency responsible for the security of travellers that was created in response to the September 11 attacks.
All luggage is scanned before being loaded into aeroplanes and if any prohibited items are detected it will be opened by airport staff and the items removed.
TSA approved locks, identified by the red diamond shaped Travel Sentry logo, can be opened using master keys. The locks are often incorporated into suitcases but TSA approved padlocks are also available.
If your suitcase can't be opened with a master key then, if they need inspect your luggage, airport staff will open it by force, cutting off padlocks etc.
To save confusion it's a good idea to note down the numbers
In theory the keys are only available to airport staff but in reality anyone with a 3D printer can print out their own master keys.
Is it Really worth Locking my TSA approved Luggage Lock? As we have seen, the 3-digit combination locks fitted to most modern suitcases offer very little or no security. At best they stop your suitcase from opening accidentally during transit, preventing your dirty laundry from spilling out on the baggage carousel.
Some suitcases (including the red suitcase in the photos) have small metal hoops incorporated into the zip-pullers allowing you to use a padlock to lock your suitcase. Although at first glance this may seem to add a second level of security, in reality, it's a waste of time. As shown in this video, zip closure suitcases can be opened quickly and easily using a ballpoint pen.
Once the lock opens you can change it to one which you can remember
Nov 08, 2018 • Cell Phones
How can I open a Mia toro carryon with a combination lock?
Is this the TSA 3 digit combo lock on the suitcase? I found a couple of Youtube videos that show how to determine what the code is for your lock. Some of them have a reset button but this technique I think works just as well. Give her a gander.
https://www.youtube.com/watch?v=MBhtFO8fSh8
Hope this helps, if its not the TSA lock let me know. I will find a good hack for you. If this did work let me know that too. Thank you.
Unable to unlock my new 19 degree aluminum suitcase
Was it opened at Customs ? If so, the lock may have been damaged.
Oct 01, 2017 • Photography
How do I make my lock lock again
Does the red indicator show ?
Is it a padlock or suitcase lock ?
It sounds like the combo has been changed.
Can not unlock combination lock of 'jeep' suitcase. Initial combo was 0,0,0. How can I reset the combination ?
What you want to do is just keep tension on the shackle, or the part of the lock that would open. With tension on it start at the opposite end and turn the numbers. You will notice that it will get "stuck" on a specific number. That's the last number in the combo. Turn the middle number till it sticks. Then the last. Tadaa! Hopethishelps
I locked my Delsey suitcase and now i don´t know how to unlock it. I need urgent assistance
if it is a combination lock and you haven't set it yet the combo should be 0000
114helpful
10answers
Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
5helpful
I can't open my samsonite luggage...the combo is stuck but I can
Turn your suitcase upside down. At this position all your numbers look upside down. Now with the help of a torch light you should see a small gap above the rotating thing (the one with which you change your number) Take the first rotating thing and rotate from 0 to 9, at some particular number you can see a small hole inside the small gap which I have mentioned before. Do the same for the next 2 rotating thing.
When you are done you can see the small hole(a tiny spring like material is seen in the hole) in all the three small gaps.
Now you can open the number lock.
Top Samsonite Photography Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
