Question about Microsoft Xbox 360 Console
I get error code e-68
I tried to put a new 20gb hardrive on my xbox 360 and the error report e-68 kept coming up saying get in touch with customer services. Can anyone help?
There's a possible hard drive issue on this.
try the ff:
-turn off your xbox
-remove your hdd from the xbox
-turn on the xbox while the hdd is removed
-if you're still getting the sme error code, your xbox needs to be repaired/replaced
-=hope that your xbox is still under warranty=- ^^
Posted on Jan 19, 2009
I just bought a 20gb hard drive for my 360.
What does the error say? Try blowing into the connectors for both the harddrive and xbox.
Mar 22, 2014 | Microsoft 20GB Hard Drive for Xbox 360
When i switch on my xbox 360 error code 68 appears and one red light on the system
Hello Sir =)
E68:
Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
Aug 16, 2010 | Microsoft 20GB Hard Drive for Xbox 360
My hard drive is not working on my XBox 360, everything is plugged in and its saying that I need to make a new account. Before this happend the XBox kept freezing.
Have you tried to format the drive? go to system settings and format the drive. warning, it will erase everything. but it will reprogram it to work properly. god's speed.
Dec 20, 2009 | Microsoft 20GB Hard Drive for Xbox 360
MY XBOX 360 HAS 1 RED LIGHT FLASHING, WHEN STOOD ON ITS SIDE THE LIGHT IS BOTTOM RIGHT
one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables. first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more. If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you. The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Jun 06, 2009 | Microsoft Xbox 360 Console
One red light - Error: E 68 - Problem code 0110
We offer a repair service.
FixMyConsole
Jun 03, 2009 | Microsoft Xbox 360 Console
My Xbox 360 can't read any disks.
hey i had this problem and taking my hardrive out, starting a game, and then shutting it off and putting my hardrive back in worked!
Mar 30, 2009 | Microsoft Xbox 360 Console
How do I find out how much memory/hardrive I have on my xbox
On your Xbox 360 guide go to the system settings. From there go to memory and that will tell you how much memory you have and let you erase some of it. Remeber say if you have a 20gb hard drive then it is not really a 20gb. It is acutally 15 or 16gbs. They format the hard drive to use it on the 360.
Mar 15, 2009 | Microsoft Xbox 360 Console
Used 20gb hd for xbox 360 doesn't work
Your best bet is to contact customer support just as it says. They may be able to help you fix the issue over the phone. Good luck.
Jan 07, 2009 | Microsoft 20GB Hard Drive for Xbox 360
System error 1 light code E 68
error 68 means that the xbox has insufficient power to operate. make sure it is directly plugged into the wall. try removing accessories on your xbox like intercoolers and USB devices.
Aug 24, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
159 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
