FixYa.com
Tags:
Hawking Data/Fax PN612  Modem
PC Laptop does not recognize the inserted modem in...
posted by coffeemaker on Jun 27, 2007
My PN612 pcmcia fax/modem has been working well on my Dell laptop for several months until now. The laptop is not reading the modem although I insert the card fully in the bay and even restart. What's happening? A friend suggested initializing the modem. Is this the only solution to get it working again (and how do I go about doing this when I have no initializing code) or is there a simpler and more obvious way that I am missing altogether?
-The Dell is using Windows XP Home Edition w/Service Pack2
-The CD software for the modem is already installed (since the modem worked before). Do I need to uninstall and reinstall the modem software?
Help!
Coffeemaker
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 27, 2007
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
yes..modems are tricky ..uninstall it let the puter find it then insert the software. if at any time u have to select a port for it u failed. it should automaticly select it. then after restart u go to control panel /modem/ and look to see if u have it there there/ next select properties/ modems/diagnistics/ query
you should see alot jibbersh letters...
then you know its working
u might want to do the last first.
CrazyLarry
Rating Locked! (?) coffeemaker has rated this solution as Helpful
Can you Help with these Modems problems?
Modems
can not connected to xboxlive
have tried to connected to xbox... Answer This...
Modems
How to install driver of HANTEL...
I have a Garuda phone... Answer This...
Modems
3Com Modem setup
Hi, I am having trouble... Answer This...
Modems
not recognizing the drive...
Not recongizing the drive.... Answer This...
Modems
hooking up roku by netflix
I have a roku box for receiving... Answer This...
Repair Service
Find Modem Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
