Question about Cuisinart DGB-500 Coffee Maker
DGB 500 Grinder
Don't know how to remove grinder from a DGB 500
  • jmorton993 Jan 22, 2009
    The grinder box will not come out because the blades are holding it in.
    Problem Solver:
  • 6 Answers
You may try opening the front cover first and removing the filter then after opening the top lid, remove the clear grinder cover and lift the grinder from the rear. After you get it out be sure to clean the motor drive shaft and the bottom of the grinder. then use a trace of vegetable oil to lubricate the motor shaft where is attaches to the grinder.
We are on our second coffee maker and it makes great coffee.
Posted on Jan 21, 2009
DGB-600 won't stop beeping and is missind grinder
The grinder cover has a white pin as a part of the cover that acts as a go between for the plastic molded post on the cover and a contact switch in the unit. Without the cover in place the molded post is not long enough to reach the contact switch and "tell" the machine it's o.k. to brew. It will beep incesssantly and do nothing. Get a replacement cover, or jury rig something to act as a replacement for the grinder cover pin. You can manually push in the switch to get it to stop beeping, but it will spring back out as soon as you release it.
Dec 19, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Mar 08, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
Coffee maker
The beeping is typically caused by the grinder safety interlock. There is a small pin on the clear grinder cover that needs to be in place so that it is depressed into the safety switch when the cover is closed. The interlock switch prevents the grinder from working when the cover is open. Check to be sure that the pin in the grinder cover is not broken.
Dec 29, 2008 | Cuisinart DGB-500 Coffee Maker
My cuisninart won't stop beeping, but every part seems to be in place how can I fix the problem?
On the Grind and Brew coffee maker the beeping is typically caused by the grinder safety interlock. There is a small pin on the clear grinder cover that needs to be in place so that it is depressed into the safety switch when the cover is closed. The interlock switch prevents the grinder from working when the cover is open. Check to be sure that the pin in the grinder cover is not broken. If you open the cover after you have started the auto-brew, it will beep but you can stop the sound by using a pen to gently depress the switch inside the small plastic post.
Grinder hard (impossible) to remove
I had the same problem and used a little grease and it worked fine. Take out the bean cup and grease the male and female parts and it should work fine.
Jul 18, 2008 | Cuisinart Thermal DGB-600 Grinder
Grinder basket removal
Vinegar instead of WD40 - I am pretty sure a good portion of the DGB-600's have this problem, but that is hearsay.
May 31, 2008 | Cuisinart Thermal DGB-600 Grinder
Grinder
1) Rinse area with vinegar/water on a cloth to break up oils
2) Fill grind chamber with ice covered in a small plastic bag - try removing again after 10 mins
Fairly common with the DGB600's IMO
-Tha Mp3 Doctor
Apr 28, 2008 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Coffeemaker DGB 500
I had the problem also.  First, I cleaned the area very well of the caramelized coffee gunk. where the grinder goes.  I also filed away a few degraded areas on the grinder's plastic housing.  Haven't had the problem since.
Oct 17, 2007 | Cuisinart DGB-500 Coffee Maker
Cuisinart DGB-500 Coffee Maker Logo
341 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
