Question about Electronic Arts Littlest Pet Shop : Jungle
Cannot adopt the giraffe
No matter how much kibble we win, the giraffe is blocked and cannot be adopted. We don't know how much kibble needed to adopt the giraffe. It is driving my daughter crazy. Giraffe's are her favorite animal.
Happend to me, too! You ACTUALLY need to put in a secret code! The secret code is...............GIRAFFE!!!
Posted on Mar 29, 2012
See this link, looks like the same problem, and it worked for me http://www.fixya.com/support/t1495184-t_unlock_giraffe_whole_game
Posted on Jun 15, 2009
Will my docs2go scanner work if I upgrade to an iPad Air and use a 30pin to fire adaptor
Not all 30 pin to fire adopters work the same. Some none Apple adopters ply work for charging. And not all hardware, will work with the adopter. Just take your doc3go into an Apple store with your adapter and ask if you can try this on a new iPad with lightning connector. Or if you don't have an adopter ask them a connector too.
Jun 26, 2014 | Office Equipment & Supplies
Phoenix Lens Adaptor
There are lots of adopters you can buy, to work with lenses from other brands. Bower has lots of adopters, but the easy one is just a Nikon to Canon adopter. The lens is manual focus, so you can't win anything by searching for an expensive solution.
Dec 29, 2013 | Cameras
Adopting Babyz on windows 7
Where I can Find Babyz for Windows 7 Please Answer If You Know :(
Jun 26, 2012 | Computers & Internet
No power,power indicator led won't lit.
Hello
That means that you have a problem with the power of your unit check the power adopter by a voltmeter if there is a 5 volts output if no voltage detected check the power source where your adopter is plugged. If there is an AC output on the outlet, check the output wire of the adopter. If the wire of the adopter have no problem on the connection check the socket where the output of the adopter is being inserted try to squeeze it while the adopter is being plugged to the AC. If the problem is still there look at the sticker of your unit if under warranty, if under warranty return it to the store where you buy it to avail the free service warranty. But if not under warranty you can fix it if you have a little knowledge in electronics. Because there is an internal damage on your unit either the power adopter of the unit or inside the unit.
If the adopter is only the problem you can open it by removing the one screw on the back of the adopter. See to it that the adopter is unplugged, then check the fuse of the adopter it is a small tube like component you can test it by a multi tester if there is a continuity it means the fuse is not busted but if no continuity it means you have to replace it with the same value. The second one is if there is a bulge capacitor. It means that if there is a capacitor that change there original shape, sometimes it blow sometime it just pop on the top of. Replace if there is a capacitor with look like that, Replace it with the value in farrad and in volts.
Hope this solution will help you
Sep 02, 2011 | KWorld TV BOX KWORLD|KW-SA220 1080I RTL TV...
I have bought a Panasonic Viera TV in UK but I live in Albania. When i want to see the analog channels my TV buzzing. May I use the TV produced for UK in another state of Europe?
Hello
The transmission system in UK is PAL-B as i know. I don't know the transmission system adopted in Albania. If transmission system is not compactable, buzz in sound will occur, as sound filter frequency will be different. Check the system adopted at your country. OK.
Apr 28, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Laptop battery terminal problem
check the power setting in control panel > power options, running from battery may be disabled
Jun 08, 2009 | Matsonic MS9337c Motherboard
Card Error
Hi , scan with anti virus sim card / the computer will stop downloading if detect viruses.Sometimes the sim card adopter can block the downloading due to imcompatibility of the sim adopter.
The Photo center can down load pictures and copy.
Dec 27, 2007 | Fuji FinePix S3000 Digital Camera
Electronic Arts Littlest Pet Shop : Jungle Logo
184 people viewed this question
Top Electronic Arts Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Electronic Arts Toy Expert? Answer questions, earn points and help others
