Question about Garden
I have an eskimo 43cc ice auger. primer bulb not pumping gas to carb this is first start of season
  • 4 Answers
SOURCE: the primer bulb will not fill
the carb needs to be taken apart and cleaned out sometimes the screen gets blocked off from the fuel it gets crystalized or the pick up line from the tank is clogged im sure its the carb
Posted on Nov 14, 2008
  • 8 Answers
SOURCE: replaced new gas line, new primer bulb, new
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
Have you checked the spark plug?
Posted on May 20, 2009
#1 Taper
  • 1040 Answers
SOURCE: 32 cc Craftsman (Poulan) gas line replacement
Yes, you are right. The larger line goes to the primer bulb and only goes into the tank about an inch. The coupling just keeps the line from pulling out of the tank. The smaller line goes to the carb. This line must rest comfortably on the bottom of the tank with the filter attached to the end.
Jim
Posted on Jun 08, 2009
  • 81 Answers
SOURCE: primer bulb doesn't pump gas
Does the primer bulb pop back out or does it come out slowly? Is the inline hose in good shape or has a crack where it can **** air in? Did you check to see if the diaphgram in the carb is pliable or is it paper-like and needs replaced. Or your carb could be stopped up.
Only one problem..I can't think of any weedtrimmer that has an inline fuel filter. They are usually located in the gas tank.
Posted on Jun 24, 2009
  • 3600 Answers
SOURCE: the primer bulb does not draw fuel thru carb
you need to buy a primer bulb kit and replace it cost about $8.00 and is easy to put in, the check valve is damaged.
Posted on Jul 18, 2009
Powerhouse tiller viper 2 cycle 43cc engine replaced primer bulb now won't start.
overhaul the carby with new diaphragms or new carby
( almost as cheap from e-bay as a overhaul kit from the mower shop)
if no carby bowl , the diaphragms that pump the fuel will be hard and nor seal properly on the seats
Apr 25, 2017 | Garden
I have a model 9400sx Eskimo ice auger with engine model#1e8xs.0464bc it's a 37.7 cc Emak made July 01 what is the proper oil to gas mixture for this unit? Thank you!
probably on the petrol cap as a 50:1
If not any where between 20:1 to 50:1 will run
only 2 stroke oil ( not engine oil)
watch the smoke from the exhaust and the correct mix is just visible smoke at rpms
smoky will be too much oil(20:1) and no smoke will be too little oil(60:1)
Jan 03, 2016 | Eskimo Mako Quantum Ice Auger
Auger won't start unless ether is sprayed into carb,then it will run until you stopauger . to re-startspray more ether
Is there a primer bulb that you need to prime? is there a choke that you can fully close proir to attempting to start.try holding full choke and throttle on initial cold engine start.if none of these help then a weak diaphram fuel pump may be the issue
Sep 06, 2014 | Ardisam Earthquake Earth Auger...
Cant get my eskimo auger to start
stroke motors do not like ethnol mix fuels as the jets are not right. It could be a cause of it not starting. Wrong oil (engine oil instead of 2 stroke ) will also cause problems as the oil will not pass through the jets.
Jan 26, 2013 | Omega Eskimo 39 In Ice Fishing Auger 8 In...
NEED carb settings for AV520 TECUMSEH
My eskimo ice auger with a 3hp 2 cycle engine. Model number is AV 520. Starts and Idles very well. Does not seem to get enough gas at the high end or want to run wide open. Any ideas?
Jan 05, 2011 | Omega Eskimo 39 In Ice Fishing Auger 8 In...
I've lost my manual for an Eskimo Ice Auger and not sure what the gas/oil mixture is. Can someone help? Thanks
The gas/oil ratio is 50:1
GAS/ OIL RATIO:
1 galllon 2.5 ounces 50:1
2 gallons 5 ounces 50:1
5 gallons 13 ounces 50:1
Jan 24, 2010 | Omega Eskimo 39 In Ice Fishing Auger 8 In...
Jiffy ice auger won't start if cold.
I
Hello. I'm kind of "out on a limb " here but my older chain saws and my Jiffy auger's the same. I use the highest octain fuel I can get (at the pump) and I think it helps. These old motors were made to run on real gas.
builderdale
Jan 08, 2010 | Omega Eskimo 39 In Ice Fishing Auger 8 In...
Bit turns when you try to start
turn down the idle . if carb is set right it should idle and bit shouldn't turn until give it gas with the hand throttle. I have know problem with mine. I start it by myself all the time.
Apr 05, 2009 | Omega Eskimo 39 In Ice Fishing Auger 8 In...
Garden Logo
229 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
