Question about Panasonic CT-20G11 TV
Picture shrinks horizontally every few seconds.
Panasonic Tv CT-20G11U. Set dead replaced: FN521 with nte2354,
BU2506df with D1877, R804 (47 Ohm), Fuse F801.
Set turns on, picture shrinks about one inch horizontally every few seconds.
  • 1 more comment
  • advisers Jan 20, 2009
    Left and right side of picture shrinks about one inch towards center, this is horizontal not vertical.
    Thanks anyway,
    Advisers.
    Thanks beforehand,
    Advisers.
  • advisers Feb 02, 2009
    Dan,
    Can you give me a solution please.
    Thanks beforehand
    Advisers.
  • 4,234 Answers
You are changing parts in the wrong circuit. The problem is in the vertical circuit. Look for the vertical IC and resolder the pins first. It should be an LA7837 or something similar. Also, check the 100ufd and 47ufd caps in the same circuit.
Keep us posted.
Dan
Posted on Jan 19, 2009
  • ABRsvcs Jan 20, 2009
    OK. I read that wrong. I'll look up the schematic tonight and try to get you a few more options.
    Dan
Panasonic ct-20g11u on channel plays sound but no picture any ideas are welcome
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Aug 04, 2016 | Panasonic Televison & Video
Panasonic TV picture shrinks to a line
There is an IC which controls the vertical deflection and over the course of a few (or 8) years with the set heating up and cooling off some of the connections work their way loose causing the symptoms you describe.
If you were to bang on the side of the set you could likely "pop" it back in but this is not a good solution. The vertical IC needs to be re-soldered. This is especially common in Panasonic sets. About 10 minutes with a soldering iron should have it worked out.
If you're handy with a soldering iron I can tell you what to look for.
Oct 09, 2008 | Panasonic CT-32G14 32" TV
High pitch squeal, buzz, no picture
Tossed the television and put a new one in.
May 16, 2009 | Panasonic Televison & Video
Panasonic CT-32G6E Intermittent single horizontal line
I would suggest to locate a part that looks like the one on this link and re solder all the pins, also check for any high power resistor nearby the IC295890 and put some fresh solder.
Let me know if you need further assistance.
Aug 07, 2008 | Panasonic CT-32G6 32" TV
Ct-36g23
In older CRT televisions the horizontal power supply can start to degrade causing the picture to shrink.
Take it to a qualified repair man to have him replace the particular components that are starting to die. This repair will require identifying the particular component and replacing it.
Often times just finding the bad component can take hours of troubleshooting by a skilled technician.
Tho, before you take it in try ruling out one simple issue like bad mains voltage. Try plugging it into a different outlet in a different part of the house.
May 01, 2008 | Panasonic CT-36G23 36" TV
Help with panasonic ct-z1410
If the picture is short top to bottom then the vertical is your problem . Check the caps in this area as they tend to become weak can't fill the verticals height . The transistor you talk about if it reads 1 ohm from the collector to the base or the emitter then the set would not work , But it will read 1ohm from the base to the emitter . Check the vertical . Good luck
Mar 14, 2008 | Televison & Video
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
Televison & Video Logo
178 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
