Internal battry error code 601 hp probook - Computers & Internet
3 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: hp notebook G61 primary internal battery replacement
1) Remove ALL power. Remove the AC adapter (Charger) and Battery. (Main battery)
2) Lay a soft static free cloth on a table, lay the laptop upside down on it, Battery Compartment facing AWAY from you.
3) Remove the Harddrive Bay Cover.
This is the large rectangular cover nearest you.
Two Philips head screws are loosened all the way, on the Right side of the cover. Then the right side of the cover is lifted up. (The Left side has plastic tabs. Swing the cover up, and out )
4) Three Philips head screws hold the Harddrive Caddy in. One on the right side, two on the left.
Remove the screws.
Grasp the Mylar tab on the Harddrive Caddy, and pull to the right.
This disengages the Harddrive from the interface of the motherboard.
Lift the Harddrive up, and out.
5) The RTC Battery is under the Harddrive Caddy.
Real Time Clock Battery.
Plugs in with a white connector, on the end of it's Black, and Red wires.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Apr 12, 2012
  • 8909 Answers
SOURCE: I have an HP Dv7-1133cl that is giving me a error
It is called the Cmos Battery and if you browse www.insidemylaptop.com you will find how to change it.
Hope that helps.
Posted on Dec 31, 2010
How do you get to the internal battery on a G56 HP Laptop?
The error message refers to the battery on the bottom of the notebook that powers it when it's not connected to A/C power. If you go into the F2 at startup or use HP Support Assistant, you can run a comprehensive battery test
Mar 16, 2015 | HEWLETT-PACKARD HP G56-122US Notebook
How to replace the 601 battery
  • If Primary (internal) Battery (601) appears in the alert message, it means the measured storage capacity of the primary (internal) battery is less than 25% of the original storage capacity. The number "601" denotes the associated error code that is recorded in the system log.
To resolve a Battery Alert message, you should perform the Battery Test in the System Diagnostics (F2) environment, and calibrate the battery for best performance.
To access the HP System Diagnostics Battery Test , turn on the computer and immediately press the esc key to display the Startup Menu. Press the System Diagnostics F2 key, and then select the Battery Test option.
if it shows bad health You might need a new battery.
Aug 07, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
What does the internal 601 Battery do, and how to replace it
Do you use your power off the mains at all (not plugged in) It will be the main battery for the laptop.
If you always leave your laptop plugged in there isn't much point in getting a new battery. Perhaps you can turn off the error message on startup?
Feb 27, 2014 | HP Pavilion dv7-1129wm Notebook
Internal Battery Error
Time to replace your laptop's main battery.
Dec 17, 2013 | HP Pavilion Computers & Internet
Error message 98.00.0C on HP 601 printer
how can i fix error 98.00.0c hp 600 m602.
Oct 29, 2013 | HP Office Equipment & Supplies
Laptop hp Compaq 6530b alerting battery code error 601
Thats the internal battery fail.
You must replace the internal battery (CMOS Battery / BIOS Battery)...
Oct 13, 2013 | Compaq Computers & Internet
Internal battery error 601 hp compaq 6735s laptop
Remove the main battery and run the ac adapter only, if everything works fine the battery will need to be replaced, if the computer continues to shutdown the problem is most likely a bad cooling fan or it needs to be taken apart and given a good cleaning.
Jun 16, 2012 | HP Compaq 6735s Notebook
Computers & Internet Logo
409 people viewed this question
David Payne
David Payne
