Question about Eforcity Samsung Bluetooth Headset WEP200 [OEM], Black Wireless Headset
Pairing a samsung wep200 headset to a samsung blackjack
I cannot figure out what I'm doing wrong, but I cannot get my samsung wep200 headset to pair with my blackjack. I will admit that I have lost the headset manual. I thought I could just go to the blue tooth menu, in the phone and have it find my headset, but it will not. Please provide instructions on how to make my headset work with my phone.
  • 1 more comment
  • Anonymous Mar 16, 2008
    My blackjack II does not find the WEP200??? Bluetooth and Visible is set to on...as is phone?
  • Anonymous Apr 17, 2008
    I am having the same problem. The default passwd for the phone isknown, the icon states there's a bluethoot connect. But when I go to mydevice> 1. ID's proper WEP200, but will not pair with the phone?I've had the phone for less than 5 weeks and I experience problems withthe blue-thooth head set for 3 of the weeks. The phone is an CDM-1450by UT STARCOM.
    Also I could use moreinformation that your manual yield on the set-up with different typesof phones. A waiting your reply
  • Anonymous Jul 30, 2008
    i cannot get my samsung into paring mode
I had to put my Nokia E62 in Pairing Mode and then manually searched for the headset to make it work.
Posted on Oct 05, 2008
Great solution. I threw away my instructions. The key is the 0000 pass key!
Posted on Jul 25, 2007
I just got it tonight so I have the manual. Turn the headset off and then hold down the button for around 8 seconds or until the light stays on. If your phone's bluetooth is on and set to "Visible" the phone should request the PIN for the headset(0000). Enter 0000 and you will be done. Unfortunately, those instructions didn't work for me. I put it in Pairing Mode and then manually searched for the headset.
Posted on Jul 19, 2007
Blue tooth is a usb transmitter. so obvisously u got to get the 2 to the right frequency. look for a small button to press on the samsung...sounds like u need the manually. look online for it. good luck. Crazylarry
Posted on Jun 27, 2007
SOURCE:
I need instructions on how to pair my WEP200 to my new cell phone please.
1 Turn your bluetooth headset off. If it is on, press and hold multi-function button(for about 4 seconds) until the LED blinks twice. 2 Prepare your bluetooth enabled phone to be ready to go to search mode. 3 Turn your bluetooth headset on in pairing mode. (Press and hold the multi-function button for almost 9 seconds. The LED will be steadily LIT.) 4 Activate the Search option in your phone. You should see Samsung WEP200 in your phone's screen. Choose that and press OK 5 The phone will ask for a passkey. Press 0000. Then press OK. Give it a few seconds, your phone and bluetooth headset will be paired.
Mar 21, 2011 | Samsung WEP200 Headset
Tip
Turn on your bluetooth on your phone and paired with your Samsung WEp200
1. go to your phone click on settings, connection/connectivity, then bluetooth.
2. turn-on your samsung wep200, your cellphone will automatically search/find for available connection.
3. choose your samsung bluetooth wep200.
4. if prompt you want to pair with it, click on yes or confirm.
5. then enter the headset passkey/code/pin: 0000
6. then your all set.
this is the website i used to pair and unlock my wep200 to my samsung impression.its quick and easy.
http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
on Feb 04, 2010 | Cell Phones
How do put Samsung WEP200 into pairing mode?
Starting with it turned off, press and hold the Multi-Function Button for some 8 seconds, until the indicator light is steadily lit in blue, thus indicating it is in pairing mode. Only then, make the device you want to pair your headset to search for new devices. After a while, the WEP200 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset will enter the stand-by mode. There might be an indication on the other device that it is connected to a bluetooth headset too. Once they are paired to each other, all subsequent connections between them should be achieved simply by bringing they both within each other's range (with their bluetooth radios turned off, of course).
By the way, if your headseet's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Sep 28, 2010 | Samsung WEP200 Wireless Headset
Can not pair cell phone with Bluetooth.
I neglegted to put the Bluetooth in pairing mode.
Nov 30, 2008 | Samsung Bluetooth?® WEP200 Headset...
Pairing with two mobiles
yes but cant use at same time with mobiles
Apr 09, 2008 | Samsung WEP200 Headset
My Sidekick don't pair this headset
I want to know they of my bluetooth Samsung WEP200 please.
Thanks
Hyacinthe AMOIKON
E-mail:[email protected]
Apr 05, 2008 | Samsung WEP200 Headset
Not working with Samsung U600
YOu will have to put the headset in pairing mode by keeping the power button pressed till the light becomes solid blue instead of blinking. Now switch on the blue tooth of your mobile and try pairing,. it should work. passcode will be 0000
Jan 29, 2008 | Samsung WEP200 Headset
Re setting Samsung WEP200
anybody know how to pair it up with an HTC Touch?
Aug 13, 2007 | Samsung WEP200 Headset
Eforcity Samsung Bluetooth Headset WEP200 [OEM], Black Wireless Headset Logo
1,451 people viewed this question
Top Eforcity Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Eforcity Radio Communication Expert? Answer questions, earn points and help others
