Question about OKI MICROLINE 320 Turbo Matrix Printer
Microline 320 turbo jibberish
It spews jibberish soon as it's turned on and loaded. Parallel port connect or not!
  • OKI Master
  • 825 Answers
Its not the main board just an incorrect driver being used. Always use the driver for the exact model from the manufacturers web site.
Posted on Jun 18, 2016
    Novelist:
  • OKI Expert
  • 297 Answers
The only thing that coould cause it to malfunction like this is a defective main board. Replacing the machine would be recommended as the board is rather expensive.
ebay has quite a few under $100
http://cgi.ebay.com/OKIDATA-OKI-Microline-320-Turbo-9-Pin-Printer-Working_W0QQitemZ120363664792QQcmdZViewItemQQptZCOMP_Printers?hash=item120363664792&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
Posted on Jan 19, 2009
Okidata Microline 320 turbo problem
Solved this problem by going into the bios and changing the port from ECP to EPP, and then uninstalling the ECP port in device manager and replacing it with a standard parallel port configuration, no problems since doing that.
May 12, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Serial Board
You have to make sure the baud rate on the printer matches to your pc or what ever application your're printing from.
hope this helps..
Mar 26, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
How to Connect an Okidata Microline 321 to a new computer
If you have the software I would install it and see if it works if it does not Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} you may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Jan 26, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
The oki data problem spewing jibberish
I USE 3-PART PAPER AND THE SECOND AND THIRD COPY AREFAINT AND HARD TO READ. THE TOP COPY IS FINE. HOW CAN I FIX THIS?
Jan 19, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata 320 turbo microline prints jibberish
sounds like a job was sent to the printer with the wrong driver. There is no way to purge it just load some paper and let it run until it stops. They make sure your emulation matches the driver youa are using. Example Epson 9pin compatiable or OKI ML320 Turbo-IBM drive you want the emulation set to Epson FX. Or if using the OKI ML320 Drive you want the emulation set to ML.
Jan 15, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 320 works with cover off only
i think its time to update your printer. but if you want to keep it then maybe the cover is not put on the right way or it is blocking the process described. in these cases you can't really solve it.
Dec 19, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 320 turbo
Are you using the parallel or serial port ? .And what driver are you using ? if correct driver is being used maybe delete and re-install the driver.
Hope this helps.
Dezzi
Oct 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printing jibberish
Hello babytenbucks,
I can help you setup your Okidata 320 printer.
Connect the printer to the printer port coming off the motherboard. Usually it's colored pink. Also known as LPT1.
If your operating system is Win XP do this. Open Control panel, open Printer & Faxes. Click File, Add new printer.
Uncheck, automatically detect & install my plug & play printer.
Click Next. Allow it to use LPT1. Click next.
There are two windows here. On the left is Manufacture on the right is Printers. Scroll through Manufacture till you find
Okidata. Under Printer, scroll down till you see Okidata ML 320 Turbo/D (IBM), click next. You can give it a new name or leave it as is. Make the 320 the default printer. You can let it print a test page. Either way re-start the system. Try another test page.
Click the link below for a .pdf file which is the manual for your
Okidata 320 Turbo.
http://www.precision.com/manuals/Okidata_ML320_321_Manual.pdf
If you do not have Adobe's pdf reader download it from the next link.
http://adobe-reader.download-express.org/now/
babytenbucks, if your still have any trouble please just post back & we'll get it solved.
Good day!
& please vote...
Feb 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
239 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
