Question about Roper RAS6233KQ Top Load Washer
Washing machine not spinning
My washing machine isn't spinning, how do we open it up to see what is wrong with it?
  • ooh181aah Feb 17, 2009
    Help....my machine won't spin. The water drains out, but it won't spin dry.
  • 198 Answers
Tip machine back and look underneath between the motor and gearcase, there is a coupler that is probably broken, Replace the coupler and you are back in business
Posted on Feb 19, 2009
5 Suggested Answers
  • 3230 Answers
SOURCE: Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Posted on May 19, 2009
dr appliance
  • 266 Answers
SOURCE: washing machine won,t drain the
something stuck in pump
Posted on Jan 27, 2011
  • 407 Answers
SOURCE: My washing machine isn't getting
Behind the washer is a plastic hose that enter the drain.Make sure that nothing is pinching it closed.You can also use drain cleaner in the drain but not in the machine.
Posted on May 12, 2011
  • 6277 Answers
SOURCE: washing machine isn't spinning and making a
If it is carrying out the wash cycle it still COULD be the brushes but it is difficult to say from a distance!
However it COULD be the control board not powering the motor on fast spin- a visual at the brushes and commutator should clarify.
Brushes
Now, a word or two of advice from a retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator, often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
It's your choice though ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
Posted on Oct 09, 2011
Vbsr2080 woww
If the drum is spinning then it's the pump if not then it could be the motor or belt
Jul 21, 2013 | Washing Machines
Washing machine isn't spinning
The problem is motor try to fix capacitor or motor shorted
Feb 18, 2013 | Washing Machines
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
Washer isn't spinning. Everything else seems to work.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Washing Machines
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
heatman101
Aug 11, 2011 | Samsung Washing Machines
WON'T SPIN
If your washing machine isn't spinning or agitating in either the delicate or the regular cycle, investigate each of these areas as a possible cause to the problem: the Selector Switch, the Clutch Assembly, or the Drive Motor. Check out this link to PartSelect.com http://www.partselect.com/washing-machine+no-spin-agitate+repair.htm it will tell you how to test each of these areas!
Jun 28, 2011 | Washing Machines
It won't drain, code nd. Hose isn't kinked.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washing machine isn't getting rid of all the water during the last spin cycle. The clothes are still very wet when it is done. I run the spin cycle more and it only rids a little water from the...
May 12, 2011 | Washing Machines
My machine is a maytag LAT2300AAE on spin cycle it will not spin and makes a noise and can smell burnt rubber what is wrong? Also how do you open it to check it out? thanks
heatman101
Sep 14, 2010 | Washing Machines
I hava a Ariston washing machine it does not spin it isn warranty but if it has a foreign object it will not be under warranty I have tried what they said going to the outlet but nothing there also how do...
Lay the drain hose down into a bucket or something similar, and let the water run out.
This will then enable you to open the door and remove your washing.
Once the water has gone you should find it will spin
Dec 07, 2008 | Washing Machines
Roper RAS6233KQ Top Load Washer Logo
228 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
