Question about Frigidaire ATF6000ES Front Load Washer
Is it OK to run a washer without water
I want to test and service a washer but have no water hook up available. Is it OK to run the washer for short periods to test the different cycles without water in the machine or even connected?
  • 943210 Jan 19, 2009
    The owner of the washer that I am wanting to test has stated that it will damage the washer to run it without the water connected. Is there any danger of this?
  • Frigidaire Master
  • 3,463 Answers
All you can test without water, is the spin and pump functions..
The heater and the wash action will not work without the correct amount of water in the washer.
Hope this helps.
Plz rate my solution.
Posted on Jan 19, 2009
  • heliconius
    heliconius Dec 31, 2012
    hey Barry, Can you explain further? We had had not enough water running into a machine for a while. Is the machine damaged and how?
The circuit breaker continues to blow off. I believe this occurs when the heating element is activated. I have replaced the heating element. The problem persists. The isolator bushings seemed to be OK....
Hi.SHORT CIRCUIT MIGHT HAPPEN I THE HEATER.IC'S MIGHT HAVE BEEN DAMAGE.or short may try to check it using a multitetster.Set it to ohms .and check continuity of the circuit.If pointer goes rapidly more than its maximum then there is short circuit in the heater.hope this helps..
Jun 18, 2011 | Kenmore Microwave Ovens
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hi, I have a qusstion. ?Can you run a pressure washer without it being hooked up to water? Thanks
the short answer is "no" and I have to ask, why would you want to, if you are thinking that you could use it to provide high pressure air to blow stuff off your deck, it won't work, the pump requires liquid in order to get enough pressure to push the water at high pressure
Mar 22, 2011 | Northstar Pressure Washer 3000 PSI
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
Hot water will not cut of
Hi, If the washer is unplugged, does the hot water shut off? If not, then you need to change the water inlet valve.
If I can help you further, please let me know.
May 16, 2009 | Washing Machines
When motor is at idle speed it surges
Try a simple test. It is ok to run the pump without water for a short time. Check idle speed without water in system to see if enginet surges. If it does not surge, then most likely the unloader/ pressure valve is causing the engine to surge when in the unloaded state. Life of unloader /pressure valve is shortened by letting system bypass for long periods of time. Enjoy
Nov 22, 2008 | Garden
Frigidaire ATF6000ES Front Load Washer Logo
4,038 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
