Monitor goes blank randomly
Viewsonic Optiquest Q91b 19'' LCD monitor goes blank. Power light goes off. I unplug 120VAC from monitor. I plug it back in and display is ok again. Sometimes I can get it back by just jiggling the plug at the monitor. I have tried a new 120VAC power cord and get the same negative results. The power cord plug is a female D connector.Will a defective internal power supply act this way or is it truly a connector mating problem?
It is the capacitor on the power to the monitor. I have replaced about 5 so for. The capacitor is like 69 cents. Open it up and look at the circuit board where the power plugs into and see if any capacitor are bubbled up. If so then its a bad capacitor.
Posted on Jul 10, 2009
My SunRay 2 keeps freezing
can someone help with one solution
Posted on Apr 07, 2011
  • 52 Answers
Try a diff monitor..if same thing happens then it is the system/if everything is fine then replace your monitor
Posted on Jan 19, 2009
  • mike anonymous Jun 04, 2009
    issue is with your monitor, if u can wiggle the wire and then sometimes it works and sometimes it does not then it will be a issue with the monitor - try a diff monitor to know for sure
Viewsonic optiquest flat panel lcd monitor power light flashes on and off with a popping niose
Look for bad caps with bulging/leaking tops as shown here:
http://s807.photobucket.com/albums/yy352/budm/OPTIQUEST/Optiquest%20Q9B/
Very common problem in all LCD monitors as you can see in my albums.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 26, 2011 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
How do I get the audio speakers to work?
Hello
-Make sure that you plug in the audio out from you computer to the audio port at the back part of you monitor -the audio controller of this monitor will be the function button in front.
the link below will contain the full manual of the monitor "http://www.viewsonic.com/products/archive/q9b.htm"
cheers.
Feb 24, 2011 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Viewsonic Optiquest Q19wb lcd Monitor goes blank after 2 secs. A couple of posts say replace the 1000uf 16v Cap My problem is i can't find them on the pcb (where are they?)
Look at the board where the AC power connector comes in that is the power supply board, there are more than one versions so it nay not have the same caps value.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic/Optiquest monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Post pictures or send them to me budmrtn@aol.com
May 15, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
Optiquest q9b-2 blank white screen (lights up when powered up) no video ??no problem with computer, video fine on another monitor, tried this monitor on several computers same problem, blank white...
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Feb 06, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
LCD doesn't power up, light just blinks
Look at the power supply first; look for burnt parts, bad capacitors, etc.
Please post back what you find
Nov 27, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Viewsonic Optiquest Q19 blanks out - just a year old
Sounds like the LCD panel inverter is going out, if not gone out completely.
Jul 18, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Monitor turns off and is dim
replace pwr inverter board...
replace the video/keyboard as well...
Feb 08, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Monitor Blanking
Buy a new monitor... It will make your eyes stop watering.
Sep 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Computers & Internet Logo
599 people viewed this question
David Payne
David Payne
