Question about Fishman Loudbox Mini Acoustic Amplifier Amp Acoustic
Fishman loudbox mini schematic
I have a rattle in my loudbox-and want to know how to take it apart
4 Suggested Answers
  • 5603 Answers
SOURCE: I have a new fishman
Does it make the noises at higher gains with nothing plugged in? If not, check your guitar cables and connectors.
Posted on Jul 11, 2011
  • 5603 Answers
SOURCE: Low volume from Fishman Loudbox
I have seen defective XLR cables so check it with an ohmmeter. It is possible the mic input preamp has been damaged. If that is the case, the unit will have to be repaired.
Posted on Aug 31, 2011
  • 1212 Answers
SOURCE: What's your problem?I have two Fishman amps.The older Loudbox 100 single channel and a Loudbox mini. I am trying to find the service manual for the older fishman as I have a fault with it and the
Fishman iis you best bet http://www.fishman.com
You can download the user manuals, they do have a block diagram, but the scan is pretty bad.
It may end up the person looking at it is going to need to rely upon their general knowledge.
My own suggestion is to pull the chassis out so you can work on it while powering it. And then work your way through the amp with either a signal source plugged in at the input, and with high impedance headphones with test lead ends, go through each audio stage carefully. until the fault is isolated. If it is not caps or the rectifiers in the power supply, faulty ground connections to chassis or faceplate, a faulty 4558 is most probable. The headphone approach is the fastest way to address this last one. If a different series of preamp chip is used, a good source for the IC datasheets in general is Digikey http://www.digikey.com and parts too.
Posted on Feb 05, 2012
Testimonial: "Thanks for your prompt and concise reply John. Indeed I have the manual however the engineer would like to work with the schematic diagram. I have emailed Fishman and await their response..The only info I can find on the website is the manual... "
Fishman Loudbox amplifier rattle sound on bass notes
Either the speakers have loosened from the faceplate, or one or more have blown. Open the amp and tighten them down. If that doesn't fix it, remove them a take them to the nearest speaker repair shop for a checkup. If blown either have them re-coned or replace them.
Oct 06, 2016 | Fishman Loudbox 100 Acoustic Guitar...
Fishman loudbox mini american power to aust power
I'm not as familiar with Fishman products, but you might find your answer on this forum: http://www.acousticguitar.com/ubbcgi/ultimatebb.cgi?ubb=get_topic;f=1;t=030507
Remember to be VERY specific about the problem, what you WANT to work, and what is NOT working as a result of your purchase.
Jan 13, 2013 | Fishman Loudbox Mini Acoustic Guitar...
Feb 05, 2012 | Fishman Loudbox 100 Acoustic Guitar...
Low volume from Fishman Loudbox Mini mic input, using brand new XLR cable and dynamic mic. Mic works just fine on instrument input using a Hi-Z cable so problem is not mik
Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
I bought a second hand Fishman LoudBox Performer. The problem is that the Aux-in for the headphone doesn't work. So sick... What can I do? tnx
I don't understand your question. The "Aux in" is just that an input that goes to the power amp. Please note that the Fishman Loudbox does NOT have a headphone jack so don't be disappointed as there plain isn't a headphone jack on this unit. I would recommend that you get a small headphone amplifier for the purpose... or even go to a thrift store and get an old stereo system that has a headphone jack and use that.
Aug 01, 2011 | Fishman Loudbox Performer Amp Acoustic
Hi, i just got Loudbox100 from US,do i need a power converter or it is fine to use it just with the adaptor?I am from Europe.
If the adapter does NOT show it handles your voltage and frequency of your mains then you need to get an adapter designed for for the Loudbox and the mains you have.
DO NOT try to use a "convertor" driving the adapter you have.
Oct 06, 2010 | Fishman Loudbox 100
The reverb (or any effect) on my Fishman Loudbox 100 has become unreliable. It goes in and out randomly.
If you have a pedal input, you may be getting FALSE trips of this.
You may have a pedal jack with switch that is marginal.
TRY putting a pedal into the effect pedal input IF your unit has that and SEE if it acts stable.
These jack and jack switch problems are a pain on all these amps... any brand.
Jan 27, 2010 | Fishman Loudbox 100
My Fishman Loudbox 100 bass speaker buzzes- what could it be? Someone suggests it could be a poor ground, and to replace the input wire, etc. Does he mean the guitar input cable? The speaker does not sound...
It is a poor ground but it is not necessarily in your amp.
If it is only buzzing when you have a guitar or other piece of equipment connected try a new lead cable.
If it buzzes all of the time......remove the cover at the rear of the amp and remove control panel.
Inspect the feed line to the input. If it is loose or broken....repair or take to have repaired.
Oct 12, 2009 | Fishman Loudbox 100
Fishman Loudbox Mini Acoustic Amplifier Amp Acoustic Logo
819 people viewed this question
Top Fishman Music Experts
Matthew Spark
Matthew Spark
Michial Gueffroy
Are you a Fishman Music Expert? Answer questions, earn points and help others
