I have a Samsung LE40F71B who have no function on the hdmi and scarts on the back. When I don`t have anything in back the meny comes up, but not in perfect condition. So what is wrong with my LCD tv w
* hdmi and scarts dosn`t work * It began slowly and now it`s no function * When hdmi cable is conected it`s just colors on the screen
  • 4102 Answers
SOURCE: hdmi not working on brand new haier hd tv
are you using hdmi leads and how are you recieving hd are you recieving it through a box
Posted on Jan 16, 2008
SOURCE: sony kdf-e42a10 42in LCD WEGA green screen
my screen is yellow
Posted on Sep 15, 2008
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
Posted on Nov 19, 2008
SOURCE: Color screen
Subsequent to my Nov 14 2008 posting... shortly thereafter, I had returned my Sony BRAVIA KDL-46V25L1 (KDL-46V2500) to Costco. Then, (after trying a 52" Samsung, whose picture was nowhere near as good as Sony in High Def , but that is another story) I purchased a newer (one year newer) Sony BRAVIA KDL-46W4100 with 120 Mhz refresh rate.
What did I find?
The same purple/green image problem (“The Problem”) exists in the newer model Sony as well ! !
I believe the actual issue is with the TV, not the cable box, in that the TV contains faulty logic in in the way it handles switching from one input format to another. Turning the TV off and back on ‘resets’ the TV, and corrects the TV display (at least in the case of my Sony BRAVIA KDL-46V25L1 (KDL-46V2500) and Sony BRAVIA KDL-46W4100).
That action should have little impact on the cable box output.
My Shaw High Definition cable box has two output options for HD: Component RGB, or a DVI output. It came with an RGB cable, and a DVI / HDMI cable (DVI end for cable box, HDMI for TV).
When I use the Component RGB, my TV does not have “The Problem”; everything is fine with all the various cable box output settings I have tried.
When I use the DVI / HDMI cable, I get the “The Problem”.
“The Problem” only appears under one specific set of conditions as noted below....
My cable box can be configured to handle output for standard definition (SD) channels in one of four different formats: Nothing, 480i , 480p, or STRETCH. (where ‘Nothing’ lets the signal pass through as-is ).
ONLY when the cable box is configured to send SD channels as 480i does “The Problem” arise.
The TV has an issue (bug in video logic?) handling the switch from 1080i to 480i, only when using the DVI / HDMI cable between cable box and TV.
IE “The Problem” only seems to occur while using both the DVI/HDMI cable, AND when the cable box channel is changed from a high definition 1080i channel to a standard definition channel AND the cable box is set to convert the output of the SD channel to 480i .
By changing the cable box to send SD channels as ‘Nothing’, or 480P, or STRETCH , and “The Problem” goes away.
Or, using the Component RGB cables, and “The Problem” goes away !
Hope this helps.
Posted on Feb 03, 2009
opherator
  • 44 Answers
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Posted on Feb 27, 2009
Tuning in skyview box to bush television
hi, how is it set up, are you using a scart lead or a hdmi lead if your using a scart lead you need to select av 1 or ext1 if your using hdmi lead you need to select hdmi 1, come back to me if your still having problems thanks.
regards
shaun
Apr 06, 2014 | Bush Industries IDLCD15W008HD LCD TV
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
I am not getting anything from HDMI connection. Is there a chip that may have gone bad
Good morning
You are certain that the HDMI cables are connected where they should be. (Language problem,mine---- ) If by component cables you mean scart connections, then they function just as well for HD as HDMI.
all the best
kolbrun
Jul 08, 2012 | Spectroniq PLTV3250 32 in. LCD TV
Just bought a ps3 secondhand but no scart lead do i need one?
You don't need a scart lead for your ps3 if you have a HD television. All ypu need is the HDMI cable (which is not included with a new PS3 but you can get very cheap from Ebay- don't bother with 'gold plated' or other 'high quality' cables as they are all the same output quality). The HDMI carries audio and video to your HD television, but you can use a scart lead for audio if and the HDMI for video if you want to use external speakers. The ps2 scart cable also works for the ps3 if you don't have a HD television. (note: a HD television is highly recommended because the quality is a hundred times better). Mine is a Samsung HD monitor which you can buy fairly cheaply.
Jul 28, 2011 | Video Game Consoles & Games
Trying to connect 46"samsung smart
200px-multiconnector-scart-chti.jpg magnify-clip.pngMulti-AV SCART adaptors with Input/Output signal switch (gold & nickel). A common misconception among game console owners is such connectors will allow RGB quality, while they are only CVBS and S-Videocompliant. THESE CAN BE USED FOR NON HD DEVICES SUCH AS YOUR DVD-VCR, AND SKYTOP BOX YOUR TV WILL HAVE AT LEAST 1 OF THE YELLOW WHITE RED COMPOSITE CONNECTION
May 05, 2011 | Computers & Internet
What is the TV channel set to to play a dvds151 dvd player?
almost all Dvd players are connected to a television by either a scart or a HDMI lead.
When you plug the scart into the back of your television (make sure its in properly) then turn the power on. on your dvd player.
This should automatically come on as scart leads send a voltage up the scart telling the tv to change to that source/av.
If it is connected via a HDMI cable then if you look at the back of your telly it will tell you what HDMI input number it is. then all you have to do is press the AV/ SOURCE button on your remote to select that number.
Hope this Helps
Little Dish Fitter
Sep 01, 2009 | Daewoo DVDS151 DVD Player
Connection advice needed
hello.on that samsung you probably have more than one hdmi conection so conect your dvd/vcr with hdmi cable to tv and sky box with hdmi to if its have hdmi or with scart if not.if you still have problems with conection,make some photos of tv,dvd/vcr and sky box all back panel and send to me (dodzio24@o2.pl) and i send you the best solution i can.
Aug 14, 2008 | Samsung Televison & Video
Grainy Picture Denon 1740 DVD and Samsung 1080P LA40M81BD
Firstly, you should alter the picture settings on the TV. Most TVs have independant settings for tuner, scart and HDMI, so you may need to do this several times. Once for each.
Excessive contrast and/or sharpness on an LCD causes graininess, particularly around the edges of moving objects.
Check and adjust the following on the TV:
  • Contrast - about 65% max
  • Sharpness - 20%
These settings are a % of maximum, so you may need to work out a value if max is not 100.
Also turn off any contrast enhancements - (Contrast + / Digital
Contrast etc.) dependant on make.
I assume that you are using the upscaling facility of the Denon 1740 via an HDMI lead. If so, disconnect any other connections between the DVD and TV, particularly scart. If the scart is connected the TV will auto-switch to the scart input when you use the DVD, and you will not get the benefit of the high def connection.
This is probably obvious, but make sure the DVD is set to 1080p scaling, and you will need to manually select the HDMI input on the TV.
May 08, 2008 | Televison & Video
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
